Full-Time 4WD System
Tay101
Taylor
San Diego
2021 Ram 1500 EcoDiesel
I could have sworn when I built a Sahara and a Rubicon on the configurator last week that you can option the Selec-Trac Full-Time 4WD System and the Rock-Trac Heavy-Duty Full-Time 4WD System with the EcoDiesel. With the introduction of the 2023 model on the configurator you can longer option the EcoDiesel with either the 2022 or 2023.
Was this a mistake on the configurator?
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Actually you never could. You can order the selec-trac on the Sahara model which is paired up with the trac-lok rear LSD, or the 4wd fulltime on the Rubicon with Rock-trac, but without the rear LSD due to the rear lockers, which is better than with no 4wd fulltime, but nowhere close to as good as the one on the Sahara with the rear LSD in a winter storm, as they were designed to work together.
Terpsmandan
Penn Yan
It wasn't available when I ordered my JLURD. Wish I had it especially after I added the GDE tune because it doesn't limit the torque in the first four gears. I can spin 37" KO2's from a standstill unless I put it in 4hi.
