2nd time overfill
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hello
Not sure if I’m imagining this. But today I was filling up from almost empty. Had about 20 miles range showing. And I reached around 15.8 gallons and it was till going. And I stopped it This happened about 2 weeks ago at the 76
Has this happened to anyone ?
22 ecodiesel
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
Hello
22 ecodiesel
Every vaporlock functions a tiny bit differently. And if it's pumping really slow, I've had them not register at all.
Some it's just positioning of the actual pump, too far or not too far enough in the neck.
Also the hotter out it is the more vapor/more readily it should stop.
AC77
AC77
AC Abegian
Los Angeles
i get what you mean, i will mess around next time i will up
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Im not sure I see the problem, doesn't your tank hold 18+ gallons ?
Based on what you said, you had two more gallons to go before full.... am I missing something ?
That was my thought as well. Tank capacity is 18.5 gallons. With the hose between the filler neck and the tank as well as the whole fuel system between the tank and the engine you can probably fit 20 gallons or more.
If I let my tank get down below 1/8 full I can get 17-18 gallons in easy.
Even if I fill up at 1/4 tank I can hit 15 gallons most of the time.
AC77
AC77
AC Abegian
Los Angeles
i have a diesel
AC77
AC77
AC Abegian
Los Angeles
diesel
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
i have a diesel
Remember diesel will “foam” when being pumped. Let it settle a minute and it’ll take more , “liquid” vs “foam”
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Tread4Lo
22'JLURD
Maybe he is talking about DEF. That's only a 5 gallon tank and then you would have 10 gallons on the ground. ?
Spank
The Wrangler has always underestimated the amount of gas you have. I've got the 3.6 and can run my needle to E and still have 3-4 gallons left.
AC77
AC77
AC Abegian
Los Angeles
Yes. The diesel tank is 18.5 gallons.
For gas in the unlimited, the tank is 21.5 gallons.
wait i knew that, i was just testing you all, lolol, how could I have not remembered this !!!
Thank you !!! need to check myself
AC77
AC77
AC Abegian
Los Angeles
no way lol,
Tread4Lo
22'JLURD
HAHA, I was just f'in around. Quite at work on a Friday afternoon. I need to find entertainment somewhere.
I wish the Jeep would be more accurate with mileage and or gallons left. Nothing like getting getting the message that you have 10 miles left. Fill up and only get 15.5 gallons in. Like no you dumb Jeep, I have 66 miles left (figuring 22 mpg).
