392 daily driver
2nd 392
Ca
So glad I missed those carb days offroading. had them in my first few cars and sucked when on a hill trying to get going with a handbrake that was non existent.
The 3A’s handbrake was so worthless it was replaced with a mod that fit and basically looked like the original but locked the actual brakes. That were also damn near worthless and typically replaced with Ford that were much larger but the same lug pattern and a simple swap. The Hurricane’s odd flathead exhaust- overhead intake with the manifold cast in the head , the carburetor mounted on top is why the 3B’s “High Hood” . To fit one in the 3A without cutting a hole in the hood as some did a very short Holley from a Falcon 6 fit by trimming the hood pinch seam for the carb bonnet. It loads up even worse, I got very good at 2 feet- 3 pedals. I’m used to it after 50 years experience.
Rubi6mt
Nj
2021 JLUR 6mt
I thought I had a good go at the 3 pedals but think you take it to the next level. Only 34 years on my end.
2nd 392
Ca
50 years is only since the Go Devil to Hurricane swap ……….. Now
Jeep Wrangler JL 392 daily driver 1BEB6C7F-2225-4BF5-BB0A-72A504D2F7F3
2nd 392
Ca
I’d love the see this list of 100.
Pssst— Hint, other Hemi’s are the majority of the top 20. It’s Not Worth Thinking About.
Jeep Wrangler JL 392 daily driver 931E58C8-444E-4E65-9542-77250A5751F1
Besides— No Modern Vehicle Remotely Sounds As Good as a 71 down with glorious sound of a big cam ! Hemi’s were at the top of that list too.
Under-Pressure
‘25 2dr Willys XR
Well I traded a Hellcat Redeye Challenger for this 392 Jeep so scratch off the top 20. I wonder what the other 80 are?
I’ve got the big cam thing covered with my 555” big block chevelle.
Jeep Wrangler JL 392 daily driver 4B64BDA7-2B21-4DAB-937B-4159BDCC1C23
2nd 392
Ca
I am green with envy.? My 69 1 of 500 HP GTX shook the walls , 6-71 Blown Chevy Willys Jeep certainly did too. Blown 454 Sanger V-Drive wasn’t bad either ( son’s now) . He!!- my HP solid lifter 283 with ~ the same HP as a penastar sounded good. I so miss the sound of a long duration- overlap cam. I had an a$$ hole neighbor who enjoyed calling the cops when I fired the boat up if I was working on it at 10.01 PM ? Hey— when are you finishing the BB ? your missing something, I can see the engine, where are all the hoses wires sensors valves pumps on and on. See- something’s wrong, it doesn’t look like this new Bronco engine
Jeep Wrangler JL 392 daily driver 87253225-48E7-4DC3-97AB-1AA32CA7BEA2
ek1
People's Republic of New York
Private
Hey guys, I get it yall need to justify your overly expensive purchase to yourselves.
The funny part about these "392 is stupid" comments is that most of y'all would have gotten a 392 if if it was priced the same as the lowest Wrangler trim and fuel costs were the same OR if money was no object to you. Then you'd go around justifying it by saying: "Yeah, you have to be a total moron not to get a 392 when it costs the same to own as a 4-cyl" :):):)
2nd 392
Ca
I like to keep the engines clean, simple & nothing to see here. Also easy to service between rounds.
Oh Yea- Well, my ultimate performance Corvette could whoop yer Chevelle . Three- not just one measly carburetor. Yer On— Pink Slips ? :CWL:
Jeep Wrangler JL 392 daily driver F135C804-7955-4DB9-842A-22387DC784CB
A ground pounding earth shaking tire shredding massive 155 HP. So take that, Huuumph………… Bet yer shakin’ in yer boots
stumblinhorse
bring it on…
Jeep Wrangler JL 392 daily driver IMG_2356
2nd 392
Ca
bring it on…
Your Mighty Confident - remember, the massive 155hp is going through an excellent two speed Power Slip, er Slide, uh Glide , that’s it, Glide. — Ya Scared Yet, Huh, Should Be !
stumblinhorse
I have a np435 putting 250hp to a 8 3/4” 3.55 open diff. Mopar muscle.
Jeep Wrangler JL 392 daily driver IMG_2776
2nd 392
Ca
Correct me if I’m wrong, as I recall the 318 & 360 were rated the same HP, the 360 with more torque though. workhorses, my son’s 318 (98 Dakota)was still running good, just burning a little oil at 328K mi when the trans failed…….. That’s Nice clean truck ?
stumblinhorse
318 Rated in 69 as 230 HP. It is not quite stock anymore. It is still original short block with a valve job to be compatible with unleaded fuel. Changed to a 4 barrel dual plane intake with a edelbrock 750 4 barrel. And long tube headers and dual 2 1/2“ exhaust.
