37s on xtreme recon package?
nyglt56
WA
2021 JL XR | 2003 TJ
Yeah driving fast over a pothole will mess up just about anything.
jack bauer
CA
2022 Rubicon XR 3.6
Finance
It seems like the XR (3.6) with the 4.56 gearing is better suited for 37s, rather than the 35's than came stock.
Perhaps the Jeep is now broke in, but almost seemed over geared on stock 35s.
Jtphoto
Thunder Bay ON
That would depend on the highways in your area and the 35” tires you run. BFGs do run small to start with. The highest speed limit we have around here is 90kph (55mph) so a little bigger 35” Duratracs are perfect with 4.56 gears. If I lived somewhere with higher speed limits that might make a difference.
jack bauer
CA
2022 Rubicon XR 3.6
Finance
Highway speed limit is 65. In the real world cruising speed is 70-75.
Also, I am running 37 KM3s so those run small, very small. I want to say 35.5'ish mounted.
Jtphoto
Thunder Bay ON
Also, I am running 37 KM3s so those run small, very small. I want to 35.5'ish mounted.
Yah it’s pretty sad when you have to buy a 37” tire to get a true 35. I do miss my true sized Pitbulls. At least the Duratracs 315/70R-17 run a little over 34” actual size at 32psi.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Speed limit on the interstate here is 80 mph, and most people drive at least 85. It is not uncommon to get caught in a group of vehicles that are driving over 90 mph. One time I was just keeping up with the flow of traffic, and glanced at the speedometer to see we were at 97 mph. I think the 4.56 gears and 35" tires on my 392 XR are just about perfect. It could stand to be geared just a bit higher for Interstate travel. But the 392 only has a 2.72:1 low range, so it feels like it could be geared just a bit lower for very technical off-road use. So the stock 4.56 gearing is a good compromise ratio for me.
Mikecoffman911
Oceanside, CA
2021 Snazzberry JLURXR
Engineer/Builder/living a great life!!!!
I put 2.5” RK springs in instead of spacers to compensate for bumper and winch. Gave me a bit extra if I choose to go 37s next time. The 35/4.56 is a nice combo.
Did you change anything with the shocks when you changed the springs? Love the way yours sits and have the steel bumper and winch as well
Jtphoto
Thunder Bay ON
Yes I swapped out shocks as well for Metal Cloak RockSports.
Jeeppaul91
Paul
PA
23 JLURXR
Real Estate
37" BFGs work great on the Extreme Recon package. They sit at 35.5" mounted, the stock 315/70/17s measured just over 34". Had to move the mounts up on the tailgate bracket. The 4.56 gears are perfect for these tires.
Did you change suspension or add lift before throwing the 37s on?
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
Upgraded axles, factory beadlocks, tailgate reinforcement, bigger brakes aren't nothing.
Do you have a link to the differences between the DJV and DJF front axles? The rear axles are the same DRF.
I think what @Stormin’ Moorman might mean what many others have asserted, if you're after 37's or higher, just get the regular Rubicon.
I think we will see an XR package with 37s and 4.88 from the factory in the future.
I'll bet we won't see that before 2027. It makes too much sense and the bean counters are risk averse. Unless the Bronco is available with 37s.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I wouldn’t be so sure….
I bent my Dana 44 front axle with a hit to a large pothole covered by snow going 10mph running 37” BFG K02s. Had less than 1500 miles on the 2022 JLU Rubicon. There is a big difference in leverage from 35-37” tires on those axle housings. I didn’t even bend mine on the FAD, it bent right next to the C on the drivers side. Now the bend isn’t too bad and is still driveable, but it still happened and it was a minor hit.
The force from impacting a tire really isn't much different between tire sizes. Bent a rim and blew out a sidewall on a bad pothole at 20mph... in a Mazda 6. It happens, even on stock sized tires.
J0E
J0e
bt39.com
There is no more leverage on the axle tube from bigger tires. It's purely the impulse on the axle. Now tire radius directly impacts the torque on the drive train as T = R Cross F. Bigger tires, bigger lever. Not so with bending the axle. It's almost always the skinny petal that bends/breaks axles. I wouldn't think 10 MPH pothole shouldn't bend a non-defective axle. I've hit plenty of big holes and rocks with my 37" KM3s and no detectable bends so far.
Exactly. I busted a stock wheel hitting a big rock going to fast on my JLR. Lucky the tire hit the rock and not my front axle or if would have busted at the FAD for sure.
Jeep Wrangler JL 37s on xtreme recon package? 2022-06-18 12.58.25
Jtphoto
Thunder Bay ON
I like the XR for the heavier diff housing, gears, better brakes and the wheels. I would have no concerns at all running 37s …
The Bronco Raptor comes with 37BFG KO2.
J0E
J0e
bt39.com
Then I'm predicting JEEP will offer 37s soon.
upgraded heavy-duty Dana 50 solid rear axle and Dana 44 front axles with upgraded half-shafts.
Until I looked up the Bronco Raptor, I was getting all my Ford news from this forum.
