More flex out of Rubi w. Xtreme Recon Package
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Have a 2022 Rubi with the Xtreme Recon package inbound for Feb. chopping front and rear fenders and putting Artec inner front/rear liners in, so this should clear 37s (MT Baja Boss A/T).
Question for the group is assuming i have the tire clearance and no rubbing issues, can I get more flex out of the jeep by replacing all 8 control arms with MetalCloak or Rock Krawler arms?
Any downside to doing this besides potentially then getting tire rub? And if so, easy fix with a 1” Teraflex spacer front and rear?
May replace the factory shocks with a set of Foxes from Accutune, but want to drive it stock first.
Roky
Roky
You won’t notice a big difference in the control arms until you change shocks and springs. There will be a small difference, mainly you won’t bind up , may not be as much clunking, but the stock set up won’t let you articulate enough to get the full potential from new arms. Even the Recon. Also, after you increase articulation, I’d recommend getting new sway links if you’re gonna use the elect disco. A double heim works a lot better. If you’re getting new wheels, 4.5” bs will work better for RK arms if you go that route.
Do I think it’s worth doing? Sure, absolutely, your just making your rig better, and that’s always a good thing…..
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
I actually have double heim sway bar links from the ORO Swayloc system I am stripping off my JLU. I was going to hold off installing it on the new Rubi until I tried the e-disconnect. The XR package comes with wheels that have 4.4” of backspacing.
With that new info, do you think it is worth doing? Or just bite the bullet and go full MetalCloak or rock Krawler lift?
Roky
Roky
If you want max articulation, you’ll need longer springs, and with that you’ll need track bars, etc… so yeah a full kit makes the most sense. MC and RK would be my recommendation, but as long as it’s a dual or triple rate spring so it will stay in place when drooping, without messing with limiting straps and the like……..here’s example of max articulation, can you imagine a factory control arm in this situation, you’d end up with a permanent twist in it. (Exaggeration) …….
Jeep Wrangler JL More flex out of Rubi w. Xtreme Recon Package B7E806BD-287F-425C-9D26-B3FBD1CF2700
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Why don't you drive it and take it off road first so you can identify its weaknesses based on your specific use case ?
Hahaha, cause I am too damn excited and love planning builds out in advance. My best friend and fellow Jeep owner says the same thing.
Jeepnutz
Don
Southern Oregon
2022 Jeep Wrangler Rubicon XR
Doing a similar setup as you when my XR arrives. If you haven't bought the Artec rear liners yet I'd highly recommend checking out Nemesis. Unlike Artec, the Nemesis liners do not rely on the pinch seem for mounting so you can open the wheel for more tire clearance. So far I have Clayton control arms with Overland Plus joints, Clayton adjustable track bars, Nemesis rear liners, Fox front hydraulic bumps, AAL highline front fenders and inner liners. Going to wait until I have my new Jeep to see how much longer spring will actually be required. As for shocks I'm going with Fox 2.5 with DSC from Accutune. Wanting a low ride height this go around.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Chopping Rubicon fenders will gain about 3.5" in the front and 2-2.5" out back. That should clear 37's just fine on an otherwise stock Rubicon. I wouldn't be concerned with tire rub, as the factory suspension won't have enough articulation to offset the increased wheelwell clearance from the chop.
If you go the suspension lift route, determine whose springs you will go with and either use their shocks that are tuned to their springs or have Accutune put a set together that will match your specific build setup.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
@FreedomFur
I would be concerned with the newly added front bumps on the XR limiting how much you can stuff tire. Just a thought reading through this thread. 🤷‍♂️
Omotose
Frank
AZ Desert
2021 Rubicon Unlimited Extreme Recon
I’m going to follow this. I have the same questions…
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
@FreedomFur
Should be easy to swap those out though.
EbyCreek
Troy
Eagle, Colorado
2021 Wrangler 392
ARMY (Retired)
Jeep Wrangler JL More flex out of Rubi w. Xtreme Recon Package 1638541833372
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
This is what I was referencing. Prob change out rubber but the tower part (whatever you call it) has been extended as well.
Jeep Wrangler JL More flex out of Rubi w. Xtreme Recon Package 92FFB405-1C36-40B5-8480-794FCD45048D
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Jesus, there is no space there, what is that maybe an 1” or 2”? Why would they do that?
Think I should just plan to buy some different “towers” above the bump stops?
