3.6 Torque Curves
The thread (title) is about torque curves, but yeah.
(not that you're saying this) When I've been replying to others, it's typically because people are saying the 3.6L makes all of its power (torque) higher in the RPM range and that's why it sucks, why it's a minivan engine and worthless off road (typically compared to the venerable 4.0L). Well, the fact is, it makes a bunch of its torque off idle, and works really well in the JL, and as an off road engine. The JL 3.6L, manual transmission, and 4.88 gearing (with front and rear lockers) is the epitome of an off road capable vehicle.
Yeah, for it's size, it does well. I'm happy with mine. I'm on 37s/4.88/8sp. It blipped right up the waterfall on Golden Spike last week. First try. And I'm usually pretty light on the skinny pedal.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Added another from Livernois (on a JT). This one was slightly different than their JL chart, and both seem to have issues with redline. Maybe the difference in gears or a speed limiter kicking in?
Livernois & unadjusted average only:
Jeep Wrangler JL 3.6 Torque Curves Livernois
All:
Jeep Wrangler JL 3.6 Torque Curves 3.6 Stock Torque Curves
AnnDee4444
AnnDee4444
'18 JLR 2.0
Found what I think might be an official crank HP dyno chart here: https://www.motales.com/engines/V8/pentastar.php
Note that all other numbers in this thread are wheel measurements. Also it doesn't look to be as installed in the JL, but the curve is likely similar.
Jeep Wrangler JL 3.6 Torque Curves power-output-pu
