Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
I ordered ours a couple days ago. Should be here with the UPS guy tonight.
DanW
Indiana
Point taken. But in fairness, it is not just the windshield defogger. It is also the weak steering box. The weak track bar. An HVAC system unable to maintain cabin temperature. The crummy auxiliary battery and charging system. A plant worker, who after four years, still hasn't learned to seat those fuses properly. An indifferent dealer body. Etc. Etc.
Owning a Jeep is clearly not for everyone. And I have learned to roll with the punches over the years. But it makes you scratch your head to see the level of incompetence, indifference, or whatever you want to call it, not to address issues that are so well known.
Wrangler directly contributes a big chunk of FCA's global profits. You would think that that alone would be enough to get them off their asses.
I haven't had any of those issues. Bad steering dampener is the extent of it, plus 2 transmission recalls. But my transmission has been fine.
I guess If I had all that going on I might be frustrated. But this Jeep has been better than the other two, by a long shot.
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
High of 7º here in Colorado Springs today...order is on the way. Nice find!
Firemadz
York, PA
2018 Wrangler JLU Rubicon, 2018 JLU Sahara
Battalion Chief
So how many plug caps did you use in the center? Also your photo of dash vents look like a long plastic strip. What is that?
Jack
I received and installed mine today. I only used 10. There are 14 holes across the center of the windshield between the two bars of the middle dash tray. I tried installing 11, but they weren’t centered and my OCD was killing me. I left the middle two holes, then installed 5 plugs, using every other hole to each side.
Firemadz
York, PA
Battalion Chief
Have you tried to remove one of those caps after you put it in? Just curious how big of a pain it might be.
They come out very easily, using a trim tool or pliers.
1JeepDad
1JeepDad
2020 Jeep Wrangler Unlimited Rubicon Sarge Green
That's great, how does it work? Do you feel the difference?
Quinn99
Quinn
North Carolina
2021 Wrangler Sahara, Chief Blue
They fit perfectly and come right out with a trim tool if needed (I also had my ocd demons activated by my initial placement). Excellent tip! Thanks!
A Sober Animal
Daniel
Chicago
2020 JLUR Recon
I ordered mine after seeing this post a few days ago. Arrived via Amazon today, and just put them in. They do help spread out the air to the sides very well. Mad props to the OP.
I ended up covering quite a few in the middle to help push air to the outside:
Jeep Wrangler JL Windshield Defroster Fix 9694ABB3-3831-4895-9ACA-3C22A91298BF
1JeepDad
1JeepDad
Looking good and enjoy a clear windshield! ?
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
Rookie! :CWL:
This is far from the 1st post that cost me money, but it's definitely the cheapest. :like:
I literally saw thread title, saw link, opened link, swiped buy.
Kraty1
Batavia IL
2018 Jeep Wrangler Unlimited JL
Sales & Marketing
I have an ‘18 and can tell you this solution works, been using these since the first snowfall I drove through when the edges of the windshield were freezing up. And yes, to those who ask in warmer climates, I had pushed the defrost button lol. They stay put and are easy to remove and move as needed.
ScoobyBlue
Lancaster County PA
Formerly 16JK Willys, now 21JL Rubicon
I wanted to verify for those of us struggling to defrost our windshields that this fix really does work. I ordered the 5/8 tubbing plug caps and plugged every other hole in the center portion. Now, the outer portion blows air equally like the center portion! Pics for reference and super easy! Thank you to everyone that has posted this fix, as a new jeeper, really appreciate it!
Last summer, I read posts about the tubing being the 1” end caps. And I ordered them in anticipation of ordering my Jeep.
Yours are 5/8”.
Craaaaap. I guess I’ll see soon enough - my Jeep is supposed to come in this month.
I did save the ASIN number from Amazon for these though just in case. Thanks!!!
four low
central New York
2018 JL
I just went to the Amazon link, and it says they are not available...
Maybe a strip of Gorilla Tape will do the job
Thunderjet
Randy
Alaska
2024 F350 6.7 diesel CC LB
Please post a link to the fix.
Thanks
