sw1928
FIXED!! Permatex repair kit is trash… Removed button from clip, cleaned window side and built it up with some solder. Filed it down til it was flat and would extend out of the clip connector. Cleaned solder point on window and used the Frost Fighter Tab repair kit ($60) and used heat gun and laser thermometer to keep it in 100-150° curing temp range for the 30 min. Attached clip to button and used small zip tie to keep slack in line through the wire guide. Used a small bead of JB Clear weld to strengthen button connection to window itself. Been holding great ever since.
