Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
If you do frequent hard pulls (pretty rare unless you run a recovery business), you'd probably want to go to a deep cycle for that reason. For the average wheeler who makes a few really hard pulls a year you are not building up that memory. Even with a high amp winch like mine, most pulls are easy and short, just getting you unstuck. That type of pull doesn't discharge the battery likely at all as it's running solely off the charging system.That is one type of memory property Nicad has. The other more common is state of charge memory. If charging at above discharged on nicad batteries will limit nominal charge state. Less voltage less capacity. While AGM memory is the opposite. Discharging below 70% capacity will effect charging state. AGM is more critical than Flooded Cell. It doesn't happen quickly on first instance but it does effect capacity life with demands. This issue has nothing to do with desulfide. It's how AGM holds charge state internally compared to a top charge state.
