alphawolff
- Jul 31, 2023
- california
- 2021 JLU
You must be forgetting the 2.0 has a damn turbocharger bolted onto it. That turbo requires it's own entire cooling system and support systems. Additional sensors, coolant lines, pumps, oil lines, etc. Add this in addition to the added failure points of being direct injection it's not even remotely close to the build complexity.It’s not a 4g63 on 36 psi, it’s a 2.0 turbo that’s not making much power and isn’t stressed out as much as you’d think.
For those of you saying the 2.0 has more parts… you must be forgetting that the 3.6 has two more rods, 2 more pistons, more injectors, the list goes on. If I were to buy a new Jeep for myself today, I would choose the 4 cylinder. I only say this as a 3.0 owner, and of course that engine is no longer available.
I’d also like to note to the OP that if you drive less than 15 miles to work everyday, you might even want to look at the 4xE.
I do not believe you've ever worked on one of these engines based on your statement. Go replace an injector on both engines and come back to me about the difficulty and cost comparison. One takes thirty minutes, the other takes hours of cursing and bitching at the heavens. I'll need some popcorn watching you try to replace the one time use high pressure fuel tube that must be replaced anytime it's loosened. It's tight fit, I assure you. The engineer who put the HPFP at the back of the head with zero room for access between the firewall deserves a quick kick to the noggin.
When I say the 2.0 sucks to work on I'm not joking. Everything is a tight fit with little to no room for access. FCA designed an entire class purely for this engine due to its shear complexity. The engine HAS been reliable across the fleet, but it doesn't change the fact that the raw amount of failure points is significantly higher than the 3.6L.
