Where are you mounting your CB?
roaniecowpony
Retired Engineer
The only issue with anything besides CB is whether or not your group has those other capabilities. Frankly, I don't want several different installations of radio gear shoehorned in every space. I may just go handheld or the Cobra. I'm not all that chatty on radios anyway. Lots of chatter, not much of it worth the noise.
For rescue, I'm likely getting a Garmin InReach or similar PLB/satcom for my hunting anyway.
RubiSc0tt
Upstate NY
2019 JLUR in Punk'n Orange
Turn Wrenches/ Write code
Typical Cobra CB install. Went with CB antenna kit on quadtratec. Very sturdy and easy to install.
@Sylent2018
Got a link for that kit? It's exactly what I'm looking for... Thanks in advance!
Taxman
Alex
Raleigh, NC
1985 CJ-7, 2018 JLUR
CPA
I mounted my 4' FireStik using the QTec kit this weekend. I used an old Midland 75-822, but was able to get 1.4 on the SWR meter across all 40 channels. Works great.
mlebofsky
Denver, CO
2019 JL Rubicon softtop
Director, DoD
For those that have run their antenna cable through the tailgate hole, does the fire-ring and/or a standard PL-259 connector make it through both sides without issue?
MandKM
2025 JLUR-X, 2008 Horizon Overland AT Trailer. No more CJ5 or ‘19 2-door JL
I used this cable: https://www.amazon.com/gp/product/B000X3C8L8/ref=oh_aui_search_asin_title?ie=UTF8&psc=1. It comes with the PL-259 separate so you have to solder it on once installed. I punched a hole in the grommet using a leather punch to ensure I still had a leak tight seal. It is rather difficult feeding the cable through the tailgate, so I would imagine even more so if it had a connector on the end.
Centurion07
'MERICA
2019 Rubicon 2-Dr
Here is my own DIY design. One piece of aluminum flat stock, some GB weld, and the factory cb bracket. No-drill install using a stock console bolt.
Jeep Wrangler JL Where are you mounting your CB? 20190805_183349
Jeep Wrangler JL Where are you mounting your CB? 20190805_183751
RebelOffRoad
Evan
22551 Shannon Circle, Lake Forest, CA 92630
www.rebeloffroad.com
2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
Jeep Builder
Jeep Wrangler JL Where are you mounting your CB? E_G03495
Now available, from Rebel Off Road, the Multi-Purpose Mount for Jeep Wrangler JK and JL. This stainless steel mount attaches to your factory/aftermarket tailgate hinge and gives you the ability to run a CB radio antenna or dust light. Made in the USA!
Features:
  • Location for mounting a CB radio antenna or a chase/dust/reverse light
  • Stainless Steel construction
  • Made In The USA
  • Works with both JK and JL factory hinges
  • Built-in bottle opener for quick cap disconnects
  • Available in a stainless steel or powder coat finish
  • Includes standoff spacers so you wont scratch the hinge paint
  • Won't obstruct the movement of your rear window when tailgate is open
Confirmed to work with these aftermarket tire carriers:
Mopar Oversized Spare Tire Carrier - Mopar Part #82215355 - Jeep JL
GenRight Off Road Swing Out Rear Tire Carrier - #RTC-10010 - Jeep JL & JK
Checkout Our Product: https://jeep.rebeloffroad.com/product-p/ror-mpm.htm
Jeep Wrangler JL Where are you mounting your CB? E_G03250
Jeep Wrangler JL Where are you mounting your CB? E_G03333
Jeep Wrangler JL Where are you mounting your CB? E_G03327
Jeep Wrangler JL Where are you mounting your CB? E_G03242
Jeep Wrangler JL Where are you mounting your CB? E_G03309
Jeep Wrangler JL Where are you mounting your CB? E_G03316
Jeep Wrangler JL Where are you mounting your CB? E_G03325
JoeValkIS
Arnold, MO
2018 Wrangler Rubicon, 2019 Can Am Spyder F3T
I went with the Uniden CMX660 mounted like this but with double stick tape because I have issues drilling holes into parts and with a Manual Transmission, there isn't as much room as you get with the Auto (photo borrowed from @TJEli ). For antenna mount, I with the CoolTech Kit because it came with the Mount, cable, and Antenna. I haven't had a chance to talk a whole lot with the radio but I think it will meet my needs quite nicely.
Jeep Wrangler JL Where are you mounting your CB? cb1-jpg
Centurion07
'MERICA
2019 Rubicon 2-Dr
That's a sweet looking little radio. My mount idea is a no drill as well. If you pop the circular cover off the side of the console, the factory bolt I used is there.
The antenna mount I made is just a dremeled piece of angular stock mounted to existing tailgate bolt openings.
Jeep Wrangler JL Where are you mounting your CB? 20190803_084905
Sting_NC_USA
Michael
Birmingham, AL
Another DIY CB Mount... Pictures of parts and tools used follow, along with shots of the rough prototype installed. Metal bar war purchased from Lowe's and large heat-shrink was secured from Amazon. Used a vice, rubber mallet and flat headed vice grips to form/twist the metal bar, then heat-shrinked the modified bar to blend and protect the center console. Used the stock bolt at the bottom console mount and the CB's stock screw to secure the CB to the bar. Very simple and CHEAP!
I had been using industrial Velcro, but it wouldn't hold up in the heat. This is a cool, semi-permanent solution that doesn't require drilling into the console.
PS: That's a "Magic Mic" magnetic mount holding the CB Mic.
Jeep Wrangler JL Where are you mounting your CB? 20190809_181330
Jeep Wrangler JL Where are you mounting your CB? 20190809_181135
Jeep Wrangler JL Where are you mounting your CB? 20190809_181231
Jeep Wrangler JL Where are you mounting your CB? 20190809_181218
WaldorfJL
Chip
Waldorf, MD
2018 Wrangler JL
I've had this hand held for a bit...a recent trip to NC cost me $160 speeding ticket, which I could have avoided had I put this back into the jeep when I switched my gear from the Subie....I went with the simplest mount that I could think of...knowing I won't have the greatest range, but it is easily removable and storable....[GALLERY=]
Jeep Wrangler JL Where are you mounting your CB? IMG_20190818_142528
Jeep Wrangler JL Where are you mounting your CB? IMG_20190818_142519
Jeep Wrangler JL Where are you mounting your CB? IMG_20190818_142505
[/GALLERY]
WaldorfJL
Chip
Waldorf, MD
2018 Wrangler JL
[/GALLERY]
