OffroadCalling77
I am purchasing a Getaway with Lithium. Wonder how different things are with the smaller Getaway than the expedition. Curious to also know if there’s different lithium wiring versus AGM.
You should ask TB what the differences are? Some examples of questions to ask.I am purchasing a Getaway with Lithium. Wonder how different things are with the smaller Getaway than the expedition. Curious to also know if there’s different lithium wiring versus AGM.
We will find out in the next 4-5 weeks. Thanks for your feedback thus far.You should ask TB what the differences are? Some examples of questions to ask.
How wide is the trailer?
What is the WMS of the suspension system?
How tall is the trailer with tent installed?
What is the tongue weight of the trailer as delivered?
What is the weight of the trailer as delivered? Clarify what is being included the weight.
Is the suspension shared with other TB model trailers or is it trailer specific.
Are all outside vendor installed items installed per manufacturer instructions?
What weight rating does the axle have?
If you want to drink the water from the trailer ask if it is potable?
As to lithium battery wiring. This would only change the charger type. Wiring would not change. With my trailer the TB installed charger would do AGM and Lithium. Same for what I installed. The TB charger was to small. The type didn’t matter.
As stated previously in this thread. I needed and still need the extra weight of a AGM battery over a lithium battery to help with needed tongue weight. Thinking lithium is half or more lighter than an AGM. Lithium is not an option for my trailer.
Also TB installed basically everything wrong that attached to the batteries, on my trailer. The accessories on your trailer is what determines how to wire it.
TB had zero understanding of how to wire the trailer properly in regards too charging, discharging, monitoring, voltage drop, fusing and so on.
I hope you get a better trailer than I did.
I just took the plunge and visited the TB website. I watched the videos for the Getaway. First time I have seen the owner. Nice to put a face to the voice.We will find out in the next 4-5 weeks. Thanks for your feedback thus far.
Also most trailers are 12 months out minimum with some companies saying two years to build. That’s insane.
Will do. When they confirm the build is about to start (should be soon) I’ll present them with these questions.I just took the plunge and visited the TB website. I watched the videos for the Getaway. First time I have seen the owner. Nice to put a face to the voice.
The video showed the same wrong battery charger in the nose cone box. It showed 2 batteries with a charger designed for one battery. The same model installed on my trailer. The cord literally says connect to one battery.
The inverter is installed in an orientation that is not recommended by the manufacturer due to heat dissipation. The inverter is not sealed. The other items in the nose cone box appear to be sealed.
It also shows the same battery boxes not installed per manufacturer installation instructions. They should be mounted from the carry handle down. You can see the mounting holes with nothing in them.
The video shows the same tire carrier mounts that were installed on my trailer. Not good. The TC frame is different.
The stove, sink, and propane tanks are the same as my trailer. You not be able to interchange propane tanks without putting back into the normal position for driving.
It looks like the base cabinetry is stronger than the upgraded marine grade I got with my trailer. I say this because my drawer slide with stove and sinks bows down in the middle, sages. The one in the video did not.
I also noticed in the video when lifting the top to show the interior no tent or gear was on the top. I mentioned this because this set up is very similar to the AT trailer I had many years ago. AT made it very clear when I purchased that all weight should be removed from the top when opening and closing. Weight should be kept to a minimum at all times. The box is top heavy.
We had the AT trailer for about 5 years. The top after about 2 years started to not line up when opening and closing. The large cargo box also started to be out of square. This is noticeable when opening and closing the rear door for the stove/sink.
This is one of the reasons I chose the Expedition model. The Expedition has a steel frame with skins to help support the top heavy box. I don’t think the Getaway has this extra support frame.
The trailer frame/footprint looks like the same frame I got with my Expedition. Not good.
You should ask the TB the questions now. You don’t need to wait till you pick up your trailer. I would not consider these trailers as custom builds. TB just assembles the same parts over and over depending on what the customer is willing to pay for. All the answers to the questions should be readily available.
I made many mistakes picking the TB. I trusted the many reviews I read, the sales staff when asking questions before purchase, paying 100% to start the build, and believing the owner truly cared about the customer after delivery. This is why I took the time to try and help the owner build a better trailer, to no end. I’m trying to help others not make the same mistakes I did.Will do. When they confirm the build is about to start (should be soon) I’ll present them with these questions.
Also, I admire the work you put into the trailer but before any work was done it seems you should have sold it and went with a date brand. I get it though. I’m sure you didn’t realize the can of worms your were opening until you were too deep in to the mess.
You are welcome. Good luck with your search.@NCJL – Thank you for this informative thread! I was about to order a Turtleback Trailer today and was looking for reviews/information and this thread made me reconsider. Not getting a TB, I'll keep looking around.
I signed up here only to say thank you!
Many excellent points!Best way to use a wrangler is to pull the trailer to a campsite. easy trails, nothing hard. Then take your light Jeep on the tough trails it was designed for and enjoy.
Getting an extremely offroad capable, fully loaed trailer for a Jeep simply makes no sense. It will get too close or go beyond the towing capabilities of the wrangler, it will limit the offroad capabilities of the Jeep so you wont use the max capabilities of the trailer. Most people end up using these trailers just to go on easy trails, it makes no sense.
A trailer that matches the jeep capabilities needs to be light. very light.
These fully loaded trailers are better pulled by a Toyota, Mercedes, Gladiator Jeep. These are much better vehicles for "overlanders". Jeeps are for rocks.
Yeah depends on one’s long term goals. Eventually I would like to have several trailer / vehicle combo choices to choose from.Best way to use a wrangler is to pull the trailer to a campsite. easy trails, nothing hard. Then take your light Jeep on the tough trails it was designed for and enjoy.
