bd100
USA Midwest
JT
Envious of those 12" brakes. Our A-frame "offroad" trailer has only 10" brakes and 14" wheels w/ all-terrain tires. The height is good for going over city curbs when necessary, and once had to turn around in a forest road through a ditch so it helped there too.
Those torsion beam axles might appreciate being stored with the weight on stands when not used for a long time. Ours has a straight axle and leaf springs, so it supposedly doesn't care as much.
I bet your paint on the frame holds up better than our "powder coating", which as is typical of aftermarket stuff is flaking off.
Edit: Pay attention to the trailer brake controller power setting. I had ours too light and almost hit stuff. Turns out with the big all-terrain tires I can run the brake controller near max w/o skidding the trailer. I bet you could do the same.
Vinman
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
What’s the tongue weight with those boxes in front?
Tongue weight with no interior and completely empty is 145 lbs., just over 11%.
Most of the heavy stuff will be behind the axle so should still be under 200 lbs when loaded. I did a quick weight transfer test and with my 180 lbs sitting on the back bumper the TW was reduced to 82 lbs.
I have the water tank, battery and diesel heater going in just behind the axle which will reduce TW but the rest of the interior and anything I put in the front cargo box should add it back.
I’ve been towing trailers for decades now and have a decent understanding of how TW effects towing and have been paying particular attention while building this trailer.
Beach Nut
Al
Fredericksburg VA
2020 JLU Sahara
Outstanding work…looking forward to seeing the interior when finished! So far…so good!
Cheers!
djthumper
Larry
North Las Vegas, NV
2021 Jeep Gladiator Sport S Eco Diesel, 2018 Jeep Wrangler Sport S 2.0
I.T.
Nice trailer! I wish I had a space that I could build something similar.
Scott97
Maine
2024 Willys 2 Door Anvil MT, 2022 Ram Rebel
Mech. Engineer, Semi-Retired
Great work, love the attention to detail. You have both skill and patience!
ObiMatt87
San Antonio, Texas
2024 Anvil JULR XR, 2018 Mojito Sahara JLU, 2018 Buick Enclave Avenir
USAF Active Duty (Retired), DAF Civilian (Current)
That is just a great all-round effort! Thanks for sharing the results of your hard work and great planning. Also looking forward to your interior install pics! 👍 👍
jim00
New England, US
JLU
Timbren 3,500 axleless suspension with 6,000 hubs and 12” brakes. Dry weight should be right at 1,600 lbs
Photos in no particular order
Amazing! What did you do to waterproot the wood as best as possible? Thanks!
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Excellent!
