Vector Off-Road
Beams37
Josh
Raleigh
2021 JLU Rubicon
I did some searching prior to buying, but couldn't find much. So, thought I would share my experience. It was easy to order, was ready quickly, packaged well, and deliver undamaged. They're instructions and templates for drilling are excellent. I would recommend both of the products I bought and will likely buy from them again.
The Shelf: It fit perfect, was well made, and easy to install.
The Table: This thing is freaking rock solid. Nothing rattles at all. Their template for drilling holes were the best templates I have ever seen!
Jeep Wrangler JL Vector Off-Road Vector Shelf
Jeep Wrangler JL Vector Off-Road Vector Table Closed
Jeep Wrangler JL Vector Off-Road Vector Table Open
Sydwaiz
Torrance, CA
2021 JLURD, 73 CJ-5
I have the shelf and just installed the E-track for the sound bar to mount my gmrs. The shelf is awesome and I couldn't live without it. I love the minimalistic design and the added space it affords. I have two rotopax mounts for water jugs mounted as well for when I go camping. The jugs can rattle a bit because they sag from the weight so I stuck some sticky foam cushions on the underside of the shelf at the corners of the jugs.
swozey
Denver, CO
How easy is the shelf to remove? Is it just a few bolts? And is it vertically adjustable at all?
I'd like a shelf but sometimes I sleep in the jeep
Sydwaiz
Torrance, CA
2021 JLURD, 73 CJ-5
It's two bolts on the inside of the roll bar on either side. .
Beams37
Beams37
Josh
Raleigh
2021 JLU Rubicon
Just did 6 hours in the Jeep on-road and a few hours of beach driving. Not a squeak from the table or the shelf. I would recommend these to anyone !!
TxJeepers
2025 JLUR '41
Mines been on for over a year. Very happy with it. When I got it I also got their cargo net. The cargo net is beef BUT I found it wouldn't tighten down enough for smaller loads. Regardless, I found the need to drill some holes to allow me to use bungie cords with it and that has worked out well.
Shelf - 5/5 would buy again
Cargo net - 3/5 wouldn't buy again
Next is a set of XG Cargo bags. I think they'll work with the shelf.
https://xgcargo.com/products/jl-gama-rear-storage-bags
I went with the Baja Designs dome light there on the left side near the tailgate latch. I have it tapped into the 12 volt outlet. Provides good light under the shelf and tailgate area. Has on/off switch. Still works when top is off. Is out of the way.
https://www.bajadesigns.com/products/led-dome-light-with-switch/?sku=398051
Jeep Wrangler JL Vector Off-Road shelf
