Turn off traction control?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
The above matches my experience, with the exception that at least some of the time mapped buttons are disabled with cruise control engaged.
I'd also note it's very possible to press the mapped Swaykill button while moving and never initiate it at a stop. The brake pedal must be depressed far enough to trigger it.
I'm not sure I understand what you're saying. Swaykill should be completely disabled if cruise is on, but there are situations where it gets enabled when you slow down after using cruise. It's a nasty bug that Tazer has been unable to replicate.
THAW
Foster
23 JL4DrRubicon
Yes, by design mapped buttons should be disabled with cruise control engaged.
I'm saying I've specifically confirmed mapped buttons are disabled during CC, in contrast to the way I interpreted points 2D and 2F2 (mapped buttons are perhaps never disabled).
In the ~1 year I've had Swaykill mapped, I have experienced 2 accidental initiations (both on road trips), but I've not been able to intentionally replicate a bug. That is, in those 2 instances it's possible I unknowingly hit the Swaykill button before switching on CC.
Ratbert
PNW
Software Engineer
I hadn't considered that we might have hit the button before turning cruise on. That seems somewhat unlikely, but it makes sense.
In theory I'll have my Jeep back this week and will be able to experiment with that.
Grayhound
Michigan
Jlurd
I hope you get your jeep back. Mine is getting an oil leak corrected. Dropped it off yesterday and found myself pouting about it. Should have it back by tomorrow.
Can't even imagine what you're going through
Ratbert
PNW
Software Engineer
It's been sitting at the shop since about a week before Christmas. I could have picked it up, but it's just about pointless since we don't trust the rear diff.
THAW
Foster
23 JL4DrRubicon
I will say I believe the intended design is that Swaykill initiation occurs only when the Jeep is at a full stop, but pressing the mapped button while in motion can - but doesn't always - start the initiation (with, I think, a sufficiently deep brake press required to complete the initiation). That is, I've witnessed inconsistent in-motion button function.
I suspect button presses might sometimes bypass parts of the conditional logic (which could cause a cruise control issue). But, Swaykill has never created a meaningful problem for me because instances of it turning on unintentionally have been rare, the sway bar hasn't actually disconnected at high/unsafe speed, and the warning lights flash.
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
18 MPH is the stupidly low limit. Drives me nuts in 4H on the beach.
100% this. If there is one nanny feature that really drives me nuts it is this one. The auto throw the trans into park if you open the door while moving thing is also freaking crazy. But after you do it once you will never do it again. Auto stop/start is annoying. But the 18mph limit has me considering a manual disconnect.
Roky
Roky
Tazer will fix all your problems……
autotragic
the cornbelt
'21 JLR 6MT
Get yourself a JL tazer mini.
It solves so many problems and opens up a whole slew of options it really is a game changer I couldn't live without mine.
Honestly if you have a Rubicon I would consider it a mandatory accessory to have.
The logic is simple once you understand it.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
A feature I really like, especially when driving in town is BrakeLock. You press the brake pedal firmly for 2 seconds and it holds the brakes until you accelerate.
Heimkehr
Pennsylvania
2021 JLU 2.0T
What trim(s) is that feature on? And is it separate and distinct from the Hill Hold feature?
I can't recall reading about "BrakeLock" in the 4+ years I've been here, nor is there any mention of it in my 2021 Owner's Manual.
SlickRicksWilly
SlickRicksWilly
Rick
2024 JLW (ordered)
Any new ideas on how to fully turn off all the skid assist, traction control nannies in 2wd? Held the button for 5 or more seconds on the wife's 2018, with the same results as mine. With how aggressive the skid assist stuff is pushing the button on the dash is pretty pointless.
Ratbert
PNW
Software Engineer
I tried Tazer's Brake Lock once. I didn't appreciate feeling like I wasn't in control, so quickly disabled it.
Roky
Roky
It’s a Tazer thing you wouldn’t understand…..🤣
