Trailer brake controller location
Quadjeeper
Winter Springs, FL
2022 392XR
retired
Thank you very for your post, I just install my kit today, and I have difficulty to find place where to put controller . Do you have picture of controller installed ?
No I don't have a pic, doubt I could even take one there, can't really even see it. Have to go by feel. It fits behind the aluminum brace in the upper left kick panel area as per the instructions. It's a PITA but does fit.
Comandore3
New Jersey
2021 Jeep Wrangler Rubikon 2door
Thank you , I will try later today.
jroever
Jens
CA
2020 JLUR
Just to add another mounting option to the list ...
Jeep Wrangler JL Trailer brake controller location F28834DF-B83A-424B-984B-7C526E9A12B7
If you don’t mind that the numbers are barely readable (they still are from the right angle!), this position for the redarc knob is still very accessible and super stealthy when not in use :)
Could also get rid of cover and mount flush if you care for readability.
Using 3073P harness made installation a breeze.
Looks much better than Mopar or redarc bezel if you ask me and is fully reversible if I ever get tired of it ...
OMTBiker
Derek
Ohio
2021 JLU 80th Snazzberry
Information Technology
Need more details and parts you used for the bezel and mounting please.
jroever
Jens
CA
2020 JLUR
Remove the 12V outlet insert as described here. You will need to 3d print a small adapter that replaces the metal 12V plug insert. (I have the zipped STL file attached, you could also use an online 3D printing service or if you pay for shipping I can send you my spare :) The rest is straight forward. I decided to add a bit of hot glue since my original 12V plug was always a bit wobbly, but that step is optional. Last step is to reconnect the power and ground to the outlet light (black to the front, and I believe orange/Gray to the rear)
Jeep Wrangler JL Trailer brake controller location IMG_9368
Jeep Wrangler JL Trailer brake controller location IMG_9330
Jeep Wrangler JL Trailer brake controller location IMG_9331
Jeep Wrangler JL Trailer brake controller location IMG_9335
74bronco_nomore
Reno
2019 JLUR, 2013 JKU, 2005 Dodge Quad cab, 2005 Audi A4
Has anyone tried these adaptors from redarc to locate the knob at the 12V power supply location? The round adaptor has a standoff that will need a 3d printed ring or rectangular bezel/flashing to fill the gap and finish the look. I would rather install the rectangular universal but can't tell if it is too small for the 12V's hole (traveling right now without jeep so can't go verify..:/ )
Jeep Wrangler JL Trailer brake controller location Screenshot_20210516-050528_Chrom
Jeep Wrangler JL Trailer brake controller location Screenshot_20210516-050713_Chrom
Comandore3
New Jersey
I just got the Mopar brake controller. So now I loose the 12volt. Does the brake controller take the power from the 12v lighter. Just wondering if I can extend the 12v wire and relocate the 12v plug. The dealership is installing it so I want to be a little more informed on what happens to the existing 12v wire. 2020 JLU.
I move 12v a bit down
Jeep Wrangler JL Trailer brake controller location fullsizeoutput_2993
ODDs
Almost Canada
2019 Hella Yella Sahara
What size hole did you drill to mount in that spot?
I don't recall the size, but it was pretty small. Maybe 3/8"? It just needs to be big enough to slip the electrical connector through. But that was two years ago, so I could be wrong.
jwilson2899
Front Royal, VA
2020 Gladiator Rubicon Launch Edition
I did and they work pretty well. I did file a small notch into the dash piece to clear the alignment bump on the Redarc bezel it’s very small and completely covered.
Jeep Wrangler JL Trailer brake controller location ABC899C5-BBD0-4F92-B282-47415BA6A2EA
74bronco_nomore
Reno
I ended up doing the exact same thing. Good install and love the controller. In that location, it is VERY convenient to use the push button feature to use only the trailer brakes in offroad conditions. Just rest your hand on the automatic shifter and push when needed during the occasional waterfal decent in Death Valley.
Jeep Wrangler JL Trailer brake controller location IMG_0177
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Looks like great choice and very clean install. One question: how/where did you connect the red "brake light trigger" wire?
(B/W power is easy, I have the blue wire from the Mopar harness I installed).
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
This is the Rubicon specific Tow Pro Trail.
I like how you whited out the letters.
Jeep Wrangler JL Trailer brake controller location IMG_3756
