Tire Deflators
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
zouch
Berkeley, CA
XJ, JLUWD
seems like these stick out a ways where they might be more likely to get ripped off in the rocks.
i have to wonder if they'd even fit in the recessed valve stem holes of the Mopar factory Beadlock wheels and clear the bead lock rings; i've sent a question to the mfr to inquire.
I am getting ready to buy these. I almost pulled the trigger on these while in Moab back in April, but did not want to tear down the tires while traveling.
https://www.apexdesignsusa.com/collections/rapid-precision-valve/products/rapid-precision-valve
AZJeepGuy
Ron
Arizona
2022 JLUR Hydro Blue
Great timing on this. I'm just looking to air down to 20 or 25 for dirt roads
After reading all the posts I added the $10 set to my cart. Screw them on and look at my dash until they are close and then unscrew. If one is a little faster than the others I can use my inflator.
Has anyone seen any that are preset to 20 or 25 PSI? I suppose getting an adjustable set would work but if a preet option was available I might go that route.
BillInDanville
Bill
Danville, CA
Jeep Wrangler Unlimited Rubicon Recon, Jaguar XJL
Unemployed
I would be very Leary of trusting the dash readout. I would also be interested to know if the TPMS gave up to the second updates.
wibornz
Ted
lansing, Mi.
www.instagram.com
I only typicality run 26 to 28 psi in my 37s. So that would not be airing down for me. Dirt roads, I usually run about 17 psi.
wibornz
Ted
lansing, Mi.
www.instagram.com
They would be fine in my ATX Slab wheels. They hav e videos on how to measure which ones you need as for as length goes. They have a regular length and an extended length set.
DewHawk
Rob
Aurora, CO
www.instagram.com
'19 Stinger GT2, '04 M3
USAF F-16 Crew Chief
Am I seriously the only psycho here that uses the back of a tire gauge to drop pressure?
Jeep Wrangler JL Tire Deflators 71pdisEL1fL
I can't fathom dropping pressure being this big of a deal. I'm on 37's so maybe the peeps with 39's and 40's that big fancy deflators make sense for. ?‍♂
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
I pull the core and when close, put them back and fine tune with the gauge.
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
AZJeepGuy
Ron
Arizona
That's how I've been doing it and overall it's OK. Getting old so threading on deflators and waiting two minutes sis attractive
blnewt
New Mexico
Just ask @cosine he knows!
I just use these, I use my timer on my phone and when it hits 2 minutes I'm down to 18 psi. Just put all 4 on at once and remove them in the same sequence and in 2 minutes you're gold! This is for my current 295/70/17 so if you're running 37s it might take 3.5 minutes, just a simple few minutes w/ your stopwatch to get the time down :)
https://www.amazon.com/dp/B07QMPVYK9?ref=ppx_yo2ov_dt_b_product_details&th=1
zouch
Berkeley, CA
XJ, JLUWD
length isn't the only consideration; the way the valve stems are recessed into some wheels (like Mopar Beadlocks) it's difficult to even get at them with fingers, and there's a good chance the lockrings will interfere with them.
WAOLIFE
Adrian & Josie
So Cal
Fiddler of Parts
Mine don’t interfere at all and I have prob one of the deepest recess on a wheel. You are right the pull tab is a little tricky. If my fingers were any fatter I would likely need to come up with a pull tool. But hey, 1.5 PSI a second. No waiting around for me ?
