Automatic Tire Deflators - recommendations?
Terrymo
Terry
2023 JLURXR 3.6 ET
I hope to have it posted in time for everyone to read it while drinking that free beer... 🤣
I'm a lot behind on several projects at the moment, possibly due to wasting too much time on the forum.
See now, I knew that reply was coming, and thought on a scale of zero to super hurtful, broken beer promises are super hurtful, and delays on project installation videos are probably only slightly hurtful. So that’s fair.
Oh_Jeepers
texas
2025 JL rubicon X
I moved from Staunā€˜s to Trailhead Tire deflators. Made in USA. I like them better than the Staun’s.
I’ve been running these as well so far they have been spot on to the pressure I set it to (13 psi)
What I really like is I install then and go bs with every one come back and unscrew them and I’m done
About the same amount of time as the 4 hose system from the time my buddy unpacks everything airs down and then put it all away
JEEPCINEMA
Cinema
2024 2-Door Sport
Apex valve stems, a timer and the onboard air pressure monitor. Done before you can finish a beer.
Auto's are never reliable and a pain in the ass to set up and recalibrate constantly.
The onboard monitor is nice.
zouch
Berkeley, CA
XJ, JLUWD
this, exactly.
the Stauns may take a bit of effort to set where you want them initially, but mine have worked perfectly in the years since i did the setup. (i've actually done the setup a couple of times as i've set them for increasingly lower pressures.)
screw 'em on, wait a little a bit, and put them away. seems like much less fuss to me than messing with a bunch of hose.
i can see where there may be a bit of risk of the adjustment changing if the lockring is not kept tight enough, but that's an easily avoidable issue.
I have a set of Staun’s. They work. For very fine adjustments they’re a pain in the ass but to let a lot of air out rather quickly they work well.
https://www.amazon.com/stores/StaunTyreDeflators/page/2E389922-7FAE-44D2-B280-930FEF07534B
Terrymo
Terry
2023 JLURXR 3.6 ET
this, exactly.
I thread on an automatic deflator one tire at a time and by the time I work my way around the vehicle the first one is about done and ready to be unthreaded. I won’t get hired on a NASCAR pit crew but I’m never the last one in a group airing down or airing up. So far no trophies or prizes have been handed out for being first.
yokramer
Snark Incarnate
But being done first means you have more time to stand around and chat which is a prize in its own right.
yokramer
Snark Incarnate
I can talk shit even while I’m still airing down…its one of my many skills
But the air of superiority of being done first while talking shit is inflating.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
this, exactly.
@Terrymo that is what happened to me on one of them, a couple of times. User error I suppose but it doesn’t seem to stay tight enough.
With the Trailhead Deflators, this has not happened to me.
mjbenedict
2018 Wrangler JL Rubicon 2 door
So you can’t talk to people while your slow automatic deflators do the job? My over-sand work fine for me. I can also carry on a discussion while they are deflating.
JEEPCINEMA
Cinema
2024 2-Door Sport
Flybaby
Bob
N. Canton, OH
2020 Wrangler
Hello Everyone,
Anyone have experience with Automatic Tire Deflators? I’m sure you all do šŸ˜…
Any suggestions on which ones are the best? Or at least most used around the Jeep community.
Thank you.
I have used the Staun brand for years and they have remained pretty accurate after all the use I have put them thru. Just takes time to set each individual one up. But the dividend is paid back at how fast you can deflate all four tires to your set pressure.
zouch
Berkeley, CA
XJ, JLUWD
don't you still need to stand there and monitor the pressure while they deflate, one at a time?
not sure if i could make them fit in the valve stem recess on my Mopar wheels anyway,..
get you a set of apex RPV valve stems and their push on gauge and be done with it. after having a set of RPVs i cant imagine airing down any other way.
https://www.apexdesignsusa.com/products/rapid-precision-valve
https://www.apexdesignsusa.com/products/precision-pressure-gauge-ppg
