35" Tire Recommendations
DHW
Atlanta
2018 Rubicon
Attorney
So between a 4Runner, a King Ranch F-150, a Raptor, and now the Jeep, I have only ever run KOs or KO2s. I did have a brief affair with the General Grabbers that were a literal mirror copy of the KOs, but I don't count that. Once my current KO2s wear out, I'd like something a little more aggressive tread-wise, but still keeps tire noise as minimal as possible. What tires have you guys run that may fit this description?
BONUS: In the spirit of general jolly, here's an unrelated pic to brighten your day:
Jeep Wrangler JL 35" Tire Recommendations 1634244953170
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I have 35" Nitto Ridge Grapplers on my Ram, good experience through 12k miles so far. Pretty quiet, too.
Blazing Saddles
Not Sure
Mountains
Jeep Jeep
Staring at this forum
I am not sure how aggressive you are looking for, but I run Nitto Ridge Grapplers on my F150 and they have been awesome. I've had no issues in rain or mud. They have been smooth on road and I haven't noticed much of a noise issue. Of course, this may vary on a Wrangler. I also haven't had KO2s to compare with, though.
  • Like
Reactions: DHW
DHW
DHW
Atlanta
2018 Rubicon
Attorney
Funny, I’ve heard nothing but good things about the Ridge Grapplers. Are they classified as MT or AT?
GATORB8
CLT NC
Hybrid
  • Like
Reactions: DHW
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
I have Nittos too. 35"x11.5" so they work on the factory rims which I like. They are MT but low road noise. Good tires, I like them a lot. Oh except for they are HEAVY. They have been pushing a new AT tire lately too.
Blazing Saddles
Not Sure
Mountains
Jeep Jeep
They are a hybrid MT/AT. I needed something that would be good for both, as my truck spends most of its time hauling things around the fields. I have hauled a 2k pound trailer around on the soft dirt and it had great traction. I haven't hauled anything really on pavement to speak to it, but the pavement grip has been fine on both dry and rainy highways. They also don't seem to pick up and fling rocks when going down gravel.
nowandthen
2014 JKUR, 1989 Toyota standard cab pickup
I've have good luck with Mickey Thompson P3 ATZ's.
+1
What you (OP) should be asking is how do the tires sound after 10-20-30,000 miles? In my experience every type of tire I bought was quiet when new. All get noisier after they wear, some worse than others.
I currently have Mickey Thompson P3 ATZ's. I have about 30,000 miles on them and they are still fairly quiet. They still have a lot of tread left. I would buy them again.
I had Nitto's and they went out of round really fast to the point that they were ruined (cupped). I know a lot of people like Nitto's so maybe I just had bad luck with my set. Still, I don't think I'd buy them again.
My .02.
blnewt
New Mexico
Just ask @cosine he knows!
+1
What you (OP) should be asking is how do the tires sound after 10-20-30,000 miles? In my experience every type of tire I bought was quiet when new. All get noisier after they wear.
My .02.
Unfortunately the ATZs are no longer available (I have a set waiting in my shed til my Patagonias wear out, should be next month, can't wait!!)
Might look at the newest Mickey Baja Boss AT, the most aggressive AT available and the sidewall biters are as aggressive as almost any tire out there!
https://www.mickeythompsontires.com/light-truck-tires/baja-boss-a-t
If you want something in the AT type tread that's not quite as aggressive the Cooper AT3 gets good reviews
https://coopertire.com/en-us/find-tires/all-tires/discoverer-at3-lt
nowandthen
Thanks, I'll definitely check them out when these wear out.
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
Well, they are heavy and high-load range, but my experience with the Toyo Open Country MT has been spectacular. They are vey quite, even after substantial wear. Their grip and durability off-road is amazing, and the manners on the road are about as good as could be expected. They are easy to balance, stable, and also seem to wear very well...my last set of Toyo MT 35s (on a Ram 2500 Cummins) got nearly 60k before I replaced it (though the last 5k or so was a touch sketchy).
The problem is they are high load range (stiff side walls) and heavy. But if those two drawbacks don't bother you, it is hard for me to think of a better MT out there.
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
I’m running Toyo AT3’s and I am very happy with them. Probably 10k on them so far and still just as quite as the KO2’s. They are a little more aggressive and don’t throw nearly as many rocks as the KO2’s did. I would absolutely buy them again.
