Automatic Tire Deflators - recommendations?
shane h.
Shane
DFW
'19 Mojito JLUR (mine), '21 Hellayella JLUR (hers)
Husband, Father, Papa
I had the Boulder Tools versions of the screw on auto deflators. Got tired of always needing to adjust them to get the PSI I wanted. Moved to the ARB EZ deflator and never looked back. Faster. More accurate. Still carry the Boulders in case someone in the group doesn't have an air down solution.
Deleted User 38384
Hello Everyone,
Anyone have experience with Automatic Tire Deflators? I’m sure you all do 😅
Any suggestions on which ones are the best? Or at least most used around the Jeep community.
Thank you.
I paid $80 for some Coyote Deflators a few years ago, and they work great, but they're a real hassle to dial in. Took me about 2 hours to dial in all four to the exact PSI I wanted.
Then I bought THESE off brand deflators from Amazon for $30 (apparently on sale for $20) and only took me about 20 minutes to get all four dialed in to 10 PSI. I keep this one in my Jeep at all times. It came with a nice sleeve that holds each of the deflators locked in by a elastic strap separately. So they don't move around, they don't bang around off each other on bumps, it's a really high quality packaging and a really nice quality deflator for the price.
I think we are at the point in the market where there are plenty of low cost options that do a great job without having to spend close to $100 on automatic tire deflators
Gregg00ss
Gregg
S Florida
'22 Sarge Green Rubicon 392xr - 2.5" RK lift, 37" Toyo's
I have over-sand deflators and they work awesome. Probably not the cheapest option compared to some on Amazon but I decided to abide by the buy once cry once theory this time around.
yokramer
Snark Incarnate
Sidewalk
Josh
Riverside, CA
JLR
I had a set of Coyote deflators* and liked them enough I will consider buying another set.
*Some drunk (left the beer and pliers behind) broke into my Jeep and stole them, with my owners manual and a cheap set of headphones. But left all my camping supplies, refrigerator, and air compressor 🤷‍♀️
JEEPCINEMA
Cinema
2024 2-Door Sport
I didn’t know ARB made this. 👍🏼
Gregg00ss
Gregg
S Florida
JEEPCINEMA
Cinema
2024 2-Door Sport
I’m gonna take a look at these.
yokramer
Snark Incarnate
I have on-board air and a 4 tire system for inflating which can also be used for deflating. I still prefer my over-sands for deflating, much easier and quicker.
Not sure how its either quicker or easier. I used to run the auto deflators on my Xterra and they took the same amount of time. The only benefit the auto deflators have over the 4 tire systems is you can put them on and drive away, however you still have to stop and take them off eventually.
On top of that the few people that do use these I wheeled with back east I was usually done well before them with my 4 tire system.
Medsker
Jon
South Jordan, Utah
Retired Engineer
I use the APEX RPV Valves. It takes me longer to take the valve cap on and off then it takes to let the air out. Sometimes I use a gauge to get them more precise which takes a little longer but you can just time the air coming out too. I also carry a pair of JT Brooks screw-on ones in case someone else needs them.
edit: Here's the link: LINK
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
If you use a 4 hose setup to air up, you could use that as well for airing down and letting it equalize. It's not automatic but easy to monitor and equalize.
TEAMSLO
North Las Vegas
This is what I have used for all my wheels. Although some designs of wheels don't work well with them as they may stick the valve outwards. Current rig has the Apex rapid deflator and use it with an ARB electronic tire gauge coupled with the ez flate rapid locking air chuck and life is great for airing down. Extremely quick and simple.
Terrymo
Terry
2023 JLURXR 3.6 ET
I have the ability to use my ARB 4 way hose system to delate, but still use individual deflators. I’m lazy and don’t feel like dragging the hoses through the mud to air down then putting muddy hoses away only to drag them back out to air back up. Doesn’t save any time or effort. I do plenty of things that don’t make sense
Terrymo
Terry
2023 JLURXR 3.6 ET
Can you set them to air down to a specific PSI? If so are they easier to adjust than the Staun style deflators?
