Tazer (Programmer) for the JL
Status
Not open for further replies.
pangmaster
Nathan
Mid Michigan
2018 JLR
Enterprise architect
Recently installed a Tazer Mini with fw 11.1.4. So far I have only set a few things like turn camera and ESS kill, but all is working perfectly. :clap:
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Don’t have time right now to fully read this thread so sorry about that. Was just installing the mini and was able to change the settings, tpms to 26 front and rear and tire size, then full reboot to save settings. Finished reboot but didn’t save settings. What am I doing wrong? Thanks.
OldGuyNewJeep
Don
CT
Did you do the two sleep cycles? I would try the process, again.
Full Reboot: Once complete, turn the ignition off, then start the vehicle. It may start and stall with the red security dot lit. If this happens, wait 10 seconds and try again, it will resume operation when it has completed its re-learn procedure. Then two sleep cycles: Shut off the vehicle, open and close the driver door and wait for a minute to be sure the dash turns off. Then start it, wait for the radio to boot up, then shut it off and open/close door and wait again.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Got it to go this morning with the sleep cycle process. Missed that upon my initial excitement and not thoroughly reading that part of the instructions.
jdhunt0
Kentucky
2019 Wrangler Unlimited
I have the newest firmware installed. I have noticed zero issues from the Tazer in the couple of weeks I have had it.
However, I installed my lift this weekend and used the Tazer to adjust for tire size. Every since then is SEEMS like my outdoor temp shows high when I first get in the Jeep and then slowly goes back to normal. Has anyone else noticed this or is this totally unrelated to the Tazer? For example, after the reboot from changing tire size the temperature showed 121 and then slowly went back down to 87. It has done this a couple other times, but not to that extreme.
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
After a reboot yes the temp will read high until it does a re-learn. After it learned it should be normal again.
Joe Paul
Jax, Fl
2018 Wrangler Unlimited Sahara
Never had that happen....had mine for over a year now.
Ezun
Chad
St. Louis area
I had this happen when I first set everything and when I unmarry and remarry after taking out the Tazer when I take to a dealership. The good news: 1) this is a known ‘issue’ and 2) it goes away after a few starts (at least for me). I read all of the threads on the Tazer/Mini before buying mine and I expected this behavior and it did settle down for me.
Not sure that helps, but at least you’re not alone!
FLECK-5
Greg
Yardley, PA
2018 JL Jeep Wrangler Rubicon
It would be nice if the Tazer had a tailgating mode that allowed you to use the radio until the battery got low then the stop start functionality kicked in and the jeep turns on to recharge the battery.
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
I accidentally changed the 4 low gear ratio on my 2020 JL rubicon.. what is the original factory setting for 4 low gear ratio? So I can put it back
Toycrusher
JLUR
Just my .02 on ESS issue... Don't stress about it. Every once in a while it resets back to start/stop. Simply hit the button to turn it back off and go on about your day.
SleepEatJeepRepeat
Newport Beach, Ca
Anyone know what this res light is, has been on since I turned on the car this morning?
Jeep Wrangler JL Tazer (Programmer) for the JL imag
SleepEatJeepRepeat
Newport Beach, Ca
It’s the security ligh it’s support flash while alarm is arming.. is it supposed to stay solid red when vehicle is in use?
OldGuyNewJeep
Don
CT
Mine has not hiccuped once since upgrading to the new firmware. What version are you on?
OldGuyNewJeep
Don
CT
Sounds like you did not properly reboot after changing settings. I would reboot as written.
Jeep Wrangler JL Tazer (Programmer) for the JL 4286210D-4755-4961-82F8-D7D460C8633A
Status
