crushinit
With the newest update I’ve noticed that when the turn signal cam is on, my dash audio screen does not display correctly. Most of the time it’s blank.
I found the latest firmware update to buggy for me. I returned to the previous version and no problems. I will wait for the next update and see.With the newest update I’ve noticed that when the turn signal cam is on, my dash audio screen does not display correctly. Most of the time it’s blank.
I have the 7" screen on my jlus without a tazer and lines also disappeared on the backup camera yesterday and I accidentally rutted my yard after a heavy rain while backing up at 6am going to work...lol. I usually pride myself on backing up well...it was strange..I took off the extender and it seems like some of the issues are not happening at this moment. I will keep monitoring.
I do know the turn camera stopped working for a few turns and then started to work again.
What makes it hard is this is totally random.
I did not write this to complain, but to find a solution. I think everyone on here that bought a tazer knew there would be some hiccups.
Another issue i have found... i scroll down on the menu to start and stop and it always says my driver door is open. No other signal and i know my door is closed.
I will end up unmarrying for awhile and see what happens, just trying different things first.
thank you for the help
Is there a way to test what that would feel like by unplugging something temporarily? Or were you being sarcastic? LolOr a full delete for those of us that want ram assist?
Then this sounds like a perfect future feature for the Tazer JL (hint hint). And let us know what happens when you unplug it. Be sure to wear a helmet just in case though. lolNope....100% serious.
I'm not at all certain how the "electric assist" to the normal hydro steering works. I have a feeling it's computer controlled at some point...since it's steering, it's entirely likely that FCA has some nanny governance system trying to "safeguard" you should it detect the electric part isn't working correctly (i.e., deleted/disconnected)....which would mean you'd have to find a way to bypass that nanny system to allow a conversion to ram assist...which frankly will be a necessity for people who are using their JLs in big rocks with big tires.
I haven't even looked at the system to see if there's a way to unplug it and see what happens.....hell, I'm a car guy and I'm looking at some of the stuff under the hood in the JL going, "WTF is that?" LOL
@RebelOffRoadWe're having issues with our JL not even recognizing the Tazer JL. Following the instructions, it won't work at all. Anyone have any luck getting someone from this company on the phone.
Good to hear you called @RebelOffRoad . As usual @joe@zauto your tech support is top notch.Sometimes I do call... I called them up based on the text they sent and walked them through the fix.
+1 Joe is a good guy. Had an issue and he took care of it!!!Good to hear you called @RebelOffRoad . As usual @joe@zauto your tech support is top notch.
