Tazer (Programmer) for the JL
Status
Not open for further replies.
echo17
Elliott
Sydney, Australia
2019 Jeep Wrangler Rubicon - Sting Gray
I purchased a JL lite and upgraded to a mini and had it installed after upgrading my tires to 37”. I was able to set tire size and psi settings. But the tire sensor warning never goes away. I’ve tried setting it between 28 and 30 psi on both front and back and have also unmarried and remarried the tazer. I have also noticed that I am getting the proper tire sensor readings; but those sensors have also gone out before every so often but then comes back after a while. I am not sure if it makes a difference, but I am also running weighted beads. This problem has never happened before the install. So wondering if it’s the Tazer or where to begin. Any advise would be much appreciated.
Jeep Wrangler JL Tazer (Programmer) for the JL FDAFC642-B0D0-46B9-B2EE-3AD2043DA8EC
Jeep Wrangler JL Tazer (Programmer) for the JL 015DD535-CDA6-40B7-80DC-3AECDB3DFDC0
melendez69
Marc
Waxhaw NC
...huh?
It's a common problem... happened to me not too long ago. Set the pressure higher than the threshold until the warning goes bye-bye, then set it to where you want.
https://www.jlwranglerforums.com/forum/threads/tpms-warning-well-this-is-odd.36894/
echo17
Elliott
Sydney, Australia
Thank you so much for the advise. Will go pump my tires back up to 38 psi before bringing it back down. Having said that, did you leave your current Tazer settings at 30 psi (or what ever the setting was at before) when you did this? Or did you change that around first?
roll
lance
mississippi
vw tdi
I have the 2020 JL diesel. Does anyone know if the Jeep JL automatically picks up when you add bigger tires? The reason I ask is because I added 35’s. I didn’t check with gps yesterday. I added my Tazer today I measured my tires and adjusted the Tazer the first measurement above 34. I gps it and it was 2mph off from gps. Not a big deal but I decided to go up to the next up. Still 2mph off. So I went to the next and next and next all the way up to 37,s still 2 mph off. Is it possible that the Jeep software is overriding the Tazer?
WhyUMad
Ryan
New Orleans, LA
Mechanical Engineer
I put mine at 22psi & run mine around 28-32psi (fluctuates with temperature). I figured if they go below 22 psi, something needs a looking at.
melendez69
Marc
Waxhaw NC
...huh?
I left my Tazer at the lowest setting (I don't recall what it is).... warning never reappeared.
Fuzzy Dave
NV
2019 Unlimited Rubicon
the setting didnt take....i do the full reboot after changing the setting, then turn truck on and off for 3 key cycles...waiting for dash lights to go out in between
roll
lance
mississippi
vw tdi
thanks because I've yet to get it change
Suffolklou
Lou
Richland Wa
2020 JLUR
I have a 2020 JLUR with the 3.6. When I got my Tazer mini I updated it (11.1.5) before using it. It would not change my tire size, no matter what I changed it to. I sent it back to Zautomotive, and they sent another one. Same result. I rolled the firmware back to 11.1.4 and it works fine. I dont know what is up with 11.1.5 and the 2020.
I also bought an AEV procal snap, it worked fine to change tire size.
I went back to the Tazer because I have the front camera. I have since updated it to 11.1.8, but haven't monkeyed with the tire size settings, so I dont know if it will have any effect.
Try 11.1.4 with your diesel.
roll
lance
mississippi
vw tdi
I’ve yet to get mine to change. In fact I was going to show someone the light show and couldn’t it to come up.
Suffolklou
Lou
Richland Wa
2020 JLUR
Did you change your firmware?
I would love to know if it works with 11.1.4 firmware
Suffolklou
Lou
Richland Wa
2020 JLUR
I like the live features but once I opened the hood with it parked, off and locked and the light show started by its self. I messaged Joe at Z automotive and he told me that that is the hood alarm.
Funny
AlanD
Alan
Scottsdale Az
2018 Nacho Wrangler Unlimited
OK question? I have a 2019 JLU with sport option. NoT originally equipped with LED'S I added the switchback leds to front turn signals so now at night they light up white, until turn signal is turned on it will flash yellow. Is there any way to have them stay on white during the day. I enabled led for front turn signal. I enabled DRL and USA, but if I use turn signal the light yellow not white.
ExitLeft
Wes
Philly ‘burbs
2003 Jeep Wrangler TJ, 2024 Jeep Wrangler Willys 4 Door
Funny
Same thing happened to me on Sunday. I had the hood open doing the wiring on my ARB twin compressor install and the light show was going. No horn beep or anything like an alarm; just the lights flashing in sequence. I just locked (or unlocked...can't remember which) the jeep from the key fob and it stopped. I only knew what it was because I read your post about it that morning.
Suffolklou
Lou
Richland Wa
2020 JLUR
I didn't even notice mine until I was in the house and looking outside.
Status
