Taking the top off by myself
hoag4147
Colleyville, TX
2022 JLUR XR
Bingo that’s my exact setup too. Thanks for the pictures @hoag4147. Literally takes 10 minutes with power tools. ?
It was very quick and easy. Of course as soon as I did this setup I found a TLP for a steal on FB marketplace and bought it, only used this setup once and still have Topsy brackets installed on back window :LOL:
I will say. Topsy kit is the way to go if you want to hang from ceiling :like:
JeepLeap
Craig
Glen Head, NY
2021 Jeep Wrangler Willys
Forgive the stupid new guy but can you tell me what this glorious looking piece of kit is and how much they run? :involve:
It’s called the TopLift Pro. And they’re around $900. Bought mine for $600 used and you can remove the top (or put it back on) very easily. Less than 5 minutes including removing the bolts.
engineXI
jank
so cal
rubicon
What is the required c!earance? I have a limited height garage due to a storage loft. There's about 4 inches between the top and the loft. Is that enough space to install hooks\straps and lift the top off?
hoag4147
Colleyville, TX
2022 JLUR XR
Most likely wouldn’t work
ELJeffe77
Orange County, Ca
2021 JLUR 2.0 Turbo, Delivered on 08/30/2021
Affiliate Marketer & Search Engine Optimization Consultant
I built it myself I got bored one day and made it myself it cost me about $50 to make though
That looks great, if it's no trouble, got a list of parts (lenght/thickness of the PVC, etc) for it? ty! :)
Gregj
Greg
West Texas
Here is a more conventional way to store the doors on it.
Jeep Wrangler JL Taking the top off by myself 96D4868F-8B5D-4A84-B756-7E6C8D3938B4
Jammer
Ft worth
Bright white JL Rubicon
Just do a homemade hoist in the garage for the roof and hangers for the doors. It is super cheap and safe. I do it myself without help.
Be very careful with those hooks like that they will put an indention in the rubber seal and water will leak in when it rains. We bought the ARC hangers. The thin piece of metal goes inside the rubber seal so it doesn't put it indention on it. That thin piece of metal there goes inside the groove instead of putting weight on the rubber. they're only like 40 bucks for a set. Friend of mine used those wheelbarrow hangers like you have and they put a indention on the rubber and water started leaking just trying to help.keep an eye on it
Jeep Wrangler JL Taking the top off by myself Screenshot_20200510-220110_Gallery
Jeep Wrangler JL Taking the top off by myself Screenshot_20210816-122328_Chrom
mlspen0
Louisville, Ky
2018 Jeep JLU Rubicon - 2024 4Runner
So I decided to see how easy it was to take the top off and on by myself. NOW you can totally take the top off by yourself easy peasy BUT putting the top on in a hot garage with no circulation sheesh get ready for a sweat fest. I also learned the front doors are heavier then the rears why did I think they all share the same weight I just don’t know lol
I used scaffolding to remove and store my top. Makes it easy to walk it back onto the scaffolding since you can set it at the same height. Not my post but here is where I got the idea from (https://www.jlwranglerforums.com/fo...age-and-removal-works-great.29016/post-723584) You can buy the scaffolding for $159 at Rural King and the blue scaffolding matches your jeep. https://www.ruralking.com/catalog/product/view/id/146043
Gahooligan
Georgia USA
2019 JLU Sport
About $200 total.. One hand pull. Door hangers off amazon. Harken lift. Panels go in the bag and on the roof. Tie downs were a PITA but will work (top hanging pic is on tie downs). I wanted easy and one person or I knew I would never take it off. The lift was well worth the $170 or so. I think the hangers were $20 a set maybe.
Jeep Wrangler JL Taking the top off by myself 20210529_174504
Jeep Wrangler JL Taking the top off by myself 20210529_141859
Jeep Wrangler JL Taking the top off by myself 20210603_202200
wren
Detroit Metro
2018 Wrangler Sahara JL
I built one of those racks too, but why are the doors upside down? You defiantly have the heavy side up. Seems like they would be more likely to fall over that way.
Gregj
I would be worried about bending the frames too if they get leaned on for some reason.
