Jeeper4xe
NC
Wrangler 4xe
I recently built a Jeep door holder and I posted the finished product in a thread and had a request for specs to build so I thought I’d create a new thread in case anyone else is interested! I’ve written it out but looking at the photos may be more helpful. Total cost of supplies under $40 from Lowe’s.
The holder can be mounted to a furniture dolly so you can roll it around, but unfortunately I have a gravel driveway so mine will be stationary.
This can be adjusted to be used for a 2 door of course.
Jeep Wrangler JL Build your own door holder - DIY instructions A28A9E20-CEA2-46F5-91AA-C061F9D6F7E2
Supplies:
3 - 10’ x 1” PVC pipes
4 - 1” pipe insulators
14 - 1” PVC elbows
10 - 1” PVC tees
Cut pipe into:
10 - 19” sections
7 - 1’ sections
4 - 6” sections
8 - 2” sections
For verticals: Connect two 19” sections and one 1’ sections with elbows. Repeat 5 times.
For the base: create the base by connecting a tee, 6” section, tee, 6” inch section, tee. Repeat for the other base. Connect three of the vertical sections into the base.
Jeep Wrangler JL Build your own door holder - DIY instructions F7DFF69F-DC5B-4A2B-80BF-C3F0AE6E77DD
Jeep Wrangler JL Build your own door holder - DIY instructions F690DE5B-BFF5-476F-A8DA-A092420BE860
For cross members and ends: create two sections each with a 2” section, tee, 2” section, elbow. Then connect the two sections at the tee with a 1’ section. Connect this to one end of the main base and add a vertical upwards from the elbows. Repeat for opposite end.
Jeep Wrangler JL Build your own door holder - DIY instructions F8567E24-C725-4F21-86E9-BFDAED4A6D18
Cut the foam pipe insulators to fit all pipe sections.
Jeep Wrangler JL Build your own door holder - DIY instructions 03F177D0-3DAB-443A-A814-3465C8C18A87
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Supplies:
14 - 1” PVC elbows
10 - 1” PVC tees
Cut pipe into:
10 - 19” sections
7 - 1’ sections
4 - 6” sections
8 - 2” sections
Very nice.
Could you also include a pic of the doors in the rack?
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
Add casters to roll around in the shop and you've got a winner!
wchevron
RI
2021 JT, 2020 JLU
I had seen a picture of this in one of your posts and built two of them for mine and my daughter's Jeep. They work great, especially with the dolly.
cOtter
Southern, Indiana
Can you share a pic on the dolly?
Tigger09
Chicago, IL
2002 TJ X x3
The first ones great if you take the doors off and put them back on every night. It takes up little space when not being used. The second one works if you have the space and keep the doors/roof off for longer periods of time.
I like both better than buying something at 10x the cost.
HDinkH
Holly
North Carolina
2018 Wrangler JL 2.0
Jeep Wrangler JL Build your own door holder - DIY instructions 20210704_161953_HDR
Supplies:
14 - 1” PVC elbows
10 - 1” PVC tees
Cut pipe into:
10 - 19” sections
7 - 1’ sections
4 - 6” sections
8 - 2” sections
Pictures of it with the doors in it?
