richk225
- Rich
- Jan 16, 2018
- New Jersey
- 2021 392Rubicon XR 2017 Jeep Grand Cherokee
- Occupation
- retired due to broken back
My question is regarding the length of the sway bar links when adding a lift especially if you are doing a custom lift that doesn’t include the links. Is there a general rule of thumb for each amount of lift you are adding, while using the stock sway bars. Do you measure the angle of the sway bar at factory lift height and try to keep it the same no matter how much lift you are adding? Say if you are adding 3” up front and 2” in the rear on a 393 Rubicon to lift and level it out what determines the length that you should use in front and rear? If you are just adding just a 1” spacer up front to level it out, how do you figure out the length that the link should be? I have received different answers from different suspension manufacturers
