Sway bar end link came off
TXSquid78
2024 Willys 4xe; 2005 Corvette
Well. Had something interesting happen to me today. Driving down the highway and heard a couple of chunks. Pulled over and checked for missing bolts, etc. Then checked the front suspension and behold, no drivers sway bar link. These are TF QDs. Only thing I can think of is the bolt came loose and the pin popped out at some point and it just went. Ugh. Life kicks you sometimes. I limped it home and ordered a new one. Hopefully better luck the second time. Just a PSA for anyone out there that has these
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
If you're swinging it up out of the way when you're wheeling. A lot of vibrating on the trail. I guess its possible the bolt came loose over time. I wouldn't think the pin would come out. Do you think its possible someone forgot to put the pin back in or it wasn't in 100% correctly?
Good thing you found out what the problem was and made it home safe.
MountainsOcean
Vancouver BC
2020 JLU Sahara
Glad you made it safe! I read the pins on the JKS quick disconnects can also bend and sometimes start to make their way out.
