Steering stabilizer struggles
RubiTrux
Summit Sponsor (Level 3)
Boone, NC
www.RubiTrux.com
Custom Wrangler & Gladiator Builder
If you had to choose the perfect steering stabilizer for your set up which one would you go with? For us, it's between the FOX 983-02-148 2.0 Factory Race Series, ATS Steering Stabilizer, Wrangler JL, Gladiator JT ( FOX 983-02-148 2.0 Factory Race Series, ATS Steering Stabilizer, Wrangler JL, Gladiator JT ) or the TeraFlex Falcon Nexus EF 2.2 Steering Stabilizer Fast Adjust 3 Settings; Wrangler JL & Gladiator JT ( TeraFlex Falcon Nexus EF 2.2 Steering Stabilizer | Jeep JL & JT ) what are your thoughts?
yokramer
Snark Incarnate
Depends on how bad the death wobble is has gotten
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
yokramer
Snark Incarnate
gek
Code Monkey
I spent my money on quality steering and suspension so I didn't have to waste money on an expensive stabilizer.
Terrymo
Terry
2023 JLURXR 3.6 ET
Metalcloak Rocksport red steering stabilizer relocation kit. Bought for under $200 on sale 2 years ago. I have other Jeep things I’d rather spend my money on than bougee steering stabilizers. No mall cred but it works just fine.
jadmt
jeff
montana
ditto AEV with relocation bracket about the same...
Dusty Dude
Colorado Springs, CO
I was looking at Metalcloaks HD steering system and it said the stabilizer relocation required at least 2” of bump stop to clear the frame. I take it that the relocation works just fine on an XR Rubi with the factory lift?
Terrymo
Terry
2023 JLURXR 3.6 ET
It worked for me with the stock XR suspension.
gato
New England
2021 JLUR
The AEV one is the best to control bump steer and any shimmy when hitting big bumps, BUT, it pulls slightly to one side. The Fox 2.0 TS (much cheaper than the ATS/Falcon) is nearly as good (but not quite as good) and has zero pull. I personally had both and I'm sticking with the Fox TS because of the zero pull on the highway.
vetygud
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
I installed the AEV/Bilstein SS with a relocation bracket and drove it for a couple of years. I didn't like the way it pushed in one direction because of it's gas charge. I swapped it out with the TeraFlex 9550 SS which isn't charged and I like the results. Much firmer than the OEM Mopar SS and a lot cheaper over the Fox and other through shaft SSs. So far I like the control and function of the TeraFlex.
Jeep Wrangler JL Steering stabilizer struggles 9550 vss
alphawolff
california
2021 JLU
just buy the factory one for the 392 or gladiator mojave. theyre like fifty bucks and beefed up compared to the normal one
