Steering stabilizer?
Fmrock164
SWFL
2018 JLU Sahara
I have a 2018 Sahara with 315/70r17
today is the first time I drove it in the hard rain and I hit a bigger puddle in the turn lane and the steering was all over. I never really had this happen with the stock tires.
but an upgraded steering stabilizer help this issue? or is there something else I should look at. It was actually kinda scary.
58Willys
Geoff
Western Washington
2018 JL Sport
Larger tires are heavier, they magnify the effects of bump steer, over a lighter stock tire. A steering stabilizer probably won’t help much.
Fmrock164
SWFL
2018 JLU Sahara
It may have been..but felt different with the bigger tires. Maybe 40mph.
Definitely a pucker moment
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
To clarify, it pulled you or you lost steering control?
You are moving more water with the bigger tires, it will tend to pull toward the tire that is pushing the water.
azwjowner
Phoenix
That is a known effect of wider tires, and 315 is a very wide tire compared to stock -- I think each tire is 2 inches wider. Water can't work its way to the edges as easily. It's a downside you'll have to live with.
Fonzilla85
Fonz
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
It happens. Actually a good reminder now that the rains are upon us to slow down especially when driving in pooled water.
Upnarms
AZ
2019 JLUR, 2003 TJ X
Upgrade your track bar to an HD one. Draglink and tie rod should be on your list too, but definitely the track bar. Otherwise, death wobble will be in your future. Bigger tires need better steering components. The factory components are barely adequate. A steering stabilizer will mask it for awhile.
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
I installed the Fox 2.0 ATS stabilizer and set the adjustment for my drive at around 17 clicks ! It’s helps a lot !! I also added a JKS track bar which makes the Drive excellent in my op.
