So, what's this wire for?
linuxos77
Greg
Blackstone, MA
2020 Wrangler Sahara
I've recently done a battery swap and AUX delete on our Wrangler, so been poking around the fuse box. I noticed something weird (I think), there's a wire/nut not like the others (middle one with gold nut) on the studs from my fuse box. It's quite thin. I bought this previous rental in 2021 (it's a 2020). There's nothing aftermarket on it, any clue what it could be? Even the wrap looks wrong.....
Jeep Wrangler JL So, what's this wire for? 1725646032143-r
Reinen
2021 Jeep Wrangler JL Rubicon
That post is typically unused. It's an add-on and could be anything. Follow the wire to see where it leads. My guess would be to a tracking device since it was previously a rental.
1Evil55
here
2018 Sport
tracker or aux lights you weren't aware of
linuxos77
Greg
Blackstone, MA
Tried half ass following it but goes deep down into the engine bay, some day if motivated enough I may dive deeper. So guessing no harm in disconnecting it?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
If you disconnect it and something obvious doesn't work, then yeah you're fine.
If the FBI or some other agency starts sniffing around, the no, you're not fine.
linuxos77
Greg
Blackstone, MA
It would be the Mounties, this was a former Canadian rental.
Reinen
I can't guarantee there is no harm in disconnecting it but there likely won't be as it's not part of the stock Jeep. Worst case scenario, you know how to fix it.
C.Sco
2023 4xe Rubicon
Almost certainly it's for a tracking device / Lojack sort of thing. That doesn't necessarily mean the tracking device is still in there, it's probably more likely that the fleet company took it out before selling it, and since the wire is only worth like 50 cents they just left it. I wouldn't waste too much time digging around for the device, but if you do want to, it probably is (or was) tucked somewhere in the engine bay or stuck to the frame or body somewhere hidden. If it was in the dash it probably would be wired for power inside the dash, not the engine bay fuse box.
In any case, should be no harm in disconnecting that wire. And if the tracking device is still in there, probably it needed that wire to work, so disconnecting the wire probably would deactivate it.
Terrymo
Terry
2023 JLURXR 3.6 ET
Don’t remove it yourself. Time to call in an expert
Jeep Wrangler JL So, what's this wire for? IMG_1724
DubaiMarauder
Alex
Fort Worth, TX.
2023 Wrangler Rubicon Unlimited EcoDiesel FarOut
Truck Driver
Look under your steering column for a little black box somewhere on the trim within reach of the driver. It will be approximately 1/2" x 1" in size with an LED and a single button on it. If you find this, it's a MOPAR EVTS system, typically installed by dealers as a "security vehicle tracking system" they can slap on and charge an extra $3k for. It's a complete scam. AutoNation typically puts them on every new vehicle so they can justify the forced upsell.
