XJ-99
Not jeep related, but funny to watch. Hopefully the link works.
Absolutely rightThis is a big one. Lotta folks frown on engine braking in snow, because you tend to leverage your front end's traction to slow down. But in reality, using engine braking forces you to slow down more naturally, avoiding the traps of rapid acceleration or deceleration.
It's been a while since I've laughed so hard, thanks for that!!!Not jeep related, but funny to watch. Hopefully the link works.
Why would less than half a tank of gas hurt a fuel pump in the cold?Adding to #2, it is also a quick way to destroy your fuel pump. When it gets cold don’t get lazy always have more than half a tank.
Fuel pumps are essentially an electric motor submerged in liquid. They function off a few sensors based on fuel level and air pressure. The engine determines how much pressure or energy to send to the line to the engine based on a moving meter. The fuel tank is outside facing and metal which will typically be the coldest part of a vehicle. When the temperature of your air is low, the molecules do not move as much causing low air pressure. You can also think about trying to drink an empty cup through a straw. At the same time cold fuel is also a factor. It’s a good rule of thumb to always have a half tank of gas during the colder months to preserve your fuel pump. I worked in Ford service for years in northeast Ohio, it was a common problem every November. Weather gets colder, people are less motivated to get fuel until it’s absolutely required and it takes a toll over time wearing out the engine in the fuel pump.Why would less than half a tank of gas hurt a fuel pump in the cold?
Wow very interesting. I like to ski and I plan on going on multiple winter road trips. If I drive till 1/4 full would that have a negative impact? Might do tbis about 10 times a winter.Fuel pumps are essentially an electric motor submerged in liquid. They function off a few sensors based on fuel level and air pressure. The engine determines how much pressure or energy to send to the line to the engine based on a moving meter. The fuel tank is outside facing and metal which will typically be the coldest part of a vehicle. When the temperature of your air is low, the molecules do not move as much causing low air pressure. You can also think about trying to drink an empty cup through a straw. At the same time cold fuel is also a factor. It’s a good rule of thumb to always have a half tank of gas during the colder months to preserve your fuel pump. I worked in Ford service for years in northeast Ohio, it was a common problem every November. Weather gets colder, people are less motivated to get fuel until it’s absolutely required and it takes a toll over time wearing out the engine in the fuel pump.
Hey everybody! Look at me! I'm a badass because I have 4WD and the law of physics no longer apply to me. I can drive 20 mph over the speed limit just like I do in the Summer! Whu, whu...whooooooooa! #CRASH!FWIW - in the area where I live (Midwest), more often than not when you see a bunch of vehicles in the ditch due to snow/ice, it's usually pickups and SUVs with 4WD. Overconfidence!
If you ever have a chance to watch a YouTube video on how it works it’s intresting! You’ll be alright I think it’s more of a preventative tip over time especially as the vehicle gets older. You just dont want to be on E.Wow very interesting. I like to ski and I plan on going on multiple winter road trips. If I drive till 1/4 full would that have a negative impact? Might do tbis about 10 times a winter.
This is all great info! Thank you!High quality chains hands down. The rest would only last a few miles. There are some newer systems that make it easier to install.
Those other things are good to get un stuck but not really for driving for miles.
There are also chains rated for off road, including snow, mud and rocks. That’s what I got 20 years ago and still going.
The picture is a pair of newer ones, but same source.
If you only have one set, they recommend to install them on the rear axle. I may have read in the manual, (or in a manual at any rate) that they ONLY recommend the rear axle, the reason being you may run into clearance issues in the front with the steering. I personally go for both front and rear after having checked all clearance points.This is all great info! Thank you!
A few questions that haven't been asked or perhaps is common knowledge.....This will be my first time taking the Rubicon into the snow. Depending on weather, Mammoth Mountain police will do a "check" to see if you have Chains or they won't let you pass so better safe than sorry.
I am thinking I'll need to buy chains. IF I had to use them as the Rubicon is Rear Wheel Drive normally, do I just need a set for the rear? Doubting I'll need front and rear but thinking if I get 1 set, they would go on the rear versus the front. Is that correct?
Also....again, if required....would you buy Chains or Cables for your Rubicon? I'm running the stock BFG tires.
Thank you
Thanks very much! I appreciate the info!If you only have one set, they recommend to install them on the rear axle. I may have read in the manual, (or in a manual at any rate) that they ONLY recommend the rear axle, the reason being you may run into clearance issues in the front with the steering. I personally go for both front and rear after having checked all clearance points.
As for the cable vs chains, the cables only advantage is less noise and vibration allowing higher speeds. Also they were designed for cars (sedan) with very little clearance. They are not as durable and don’t offer as much traction, specially if you get the tire(s) off the road.
Very important: ALWAYS check and re-tight the chains after rolling 30-60 feet. Lots of horror stories about chains ripping off fenders and destroying all sort of things. Chains like hi-lift jacks can do damage if not properly managed.
