Torero
You don’t need snow tiresYou don't need chains.
You don’t need 4x4
You don’t need a winch
You don’t need a hi-lift
ETC.
Nobody NEEDS anything. You just have to ask around to get that conclusion
Cool! I like it. Keep on keeping on.Heh Heh, well I GOT chewed out for always ending my posts with--"WHATEVER" !!! so
I shortened it !
Sometimes, depending on my answer--it would be stupid for me to say WHATEVER--so I don't use either--
JIMBO
Indeed, people who think 4wd helps them stop truly need 4wd (and lockers and a winch) to help them get out of the ditch or medianThis is a genius quote! Probably the smartest sentence that will pop up on this feed, and something even most long-time 4WD drivers forget.
I'd hate to fool with chains, though many years ago with rear wheel drive I had to. If the road is not paved then I would think you will hit ruts, mud, ice and packed snow on the trail roads. Personally I would want a mud / deep tread tire for that if I did it frequently in bad weather.Hey guys, so thanks for the tips. I guess I was looking for tips more along the lines of going up to the mountains (Mt. Hood area) on the forest roads and what not. So more off-road snow tips vs on road.
In ThevDC area, I see lots of cars go off the roads, mostly due to stupidity. It doesn’t matter what car you drive, excessive speed is the worst thing you can do in crappy winter conditions. Just because you may now have a Jeep doesn’t mean you drop it into 4x and drive the speed limit. Go slow, get a feel for the conditions, and still go slow. Don’t be in a hurry. Use a lot of stopping distance. In some cases, mild acceleration can help recover from a slide/skid, but don’t go fast enough that you need to use it. People driving trucks and SUVs tend to think they have the best vehicle for snow and finally they get to use it—that’s who I tend to see on the sides of the road wondering why their vehicle didn’t save them.So I’ve never lived in a place that had snow readily available to drive in. Or if I did, well, a mustang isn’t exactly the vehicle to do it in.
Anyways, what are the general rules to follow besides slow down and plenty of space? I’m talking like do you air down to get a wider footprint? Or do you stay inflated to get down to to packed stuff? Do you put chains on when aired down? What kind of chains are best when I headed up into the mountains? Should I use lockers in snow? Etc etc...
Thanks!
That is the exact reason for probably 98% of snow related accidents here. People driving too fast and then losing control when having to slow down.Indeed, people who think 4wd helps them stop truly need 4wd (and lockers and a winch) to help them get out of the ditch or median
We have bad snow but only occasionally here in WV. Probably 75% of the time when someone is in the median or a ditch it's a jacked up 4wd truckThat is the exact reason for probably 98% of snow related accidents here. People driving too fast and then losing control when having to slow down.
Adding to #2, it is also a quick way to destroy your fuel pump. When it gets cold don’t get lazy always have more than half a tank.Lifelong resident of Ohio and Michigan here, so I’ll start. First of all, not all snow is the same. There is fluffy wet snow, dryer icy snow, and the worst of all, ice disguised as snow.
I’ll start a list, and sure others will add to it.
1. Tire pressure x have it properly inflated. Don’t need to be extra high or extra low. But notice that cold temps will likely cause your tire pressure to drop, so may need to add a bit of air to keep it properly inflated.
2. As a general rule I try to keep my gas tank at least 1/4 full (and preferably 1/2) when it’s super cold. It is better on the engine, and lowers the likelihood of you running out of gas in freezing temps.
3. Chains aren’t necessary.
4. Definitely slow down. If it’s ice, essentially no driving techniques matter beyond going slower.
5. When you’re on an open stretch, test the slipperyness of the road by accelerating to a slow speed and then testing your brakes. Better to know what the roads are like before you’re around other cars. I do this when leaving my driveway in the morning.
6. If you have a Sahara with the FT4WD, this is a perfect time for it.
7. For all other Jeeps, here’s a general rule. Never use PT4WD when you can see the pavement. If the roads are genuinely covered in snow, you’re fine using it for extra traction. But not if they’ve been plowed.
8. Don’t drive around wirh your lockers on, especially if the roads have been plowed. But if you do happen to get stuck, they can be helpful.
Lmao I've been wondering the same since earlier in the yearSorry, off topic, and I enjoy your posts, but what does W.E. mean?
Well, there are different road conditions than just snow covered or plowed, so I think the answer is not that easy. If there is a chance of slippage, or slush or anything other than totally cleared, I use my 4 high if I feel the need and never worry about it. Better safe than sorry.7. For all other Jeeps, here’s a general rule. Never use PT4WD when you can see the pavement. If the roads are genuinely covered in snow, you’re fine using it for extra traction. But not if they’ve been plowed.
Well, since lockers only work in 4 low, I would certainly hope one is not driving all around in 4 low with the lockers on. If you are, it's going to take you a long time to get anywhere and yoju will feel the constant binding.8. Don’t drive around wirh your lockers on, especially if the roads have been plowed. But if you do happen to get stuck, they can be helpful.
