Severe Pull to Right
Slawder95
Seth
Katy, TX
2019 Wrangler Sport Unlimited
By looking at this could anyone tell me why it might pull so hard to the right and what to fix? No accidents or frame damage, adjustable front and rear track bar.
Jeep Wrangler JL Severe Pull to Right IMG_6927
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Try rotating the tires and see if anything changes before throwing parts and time at it.
I'd like a bit more caster. You can add the Mopar lift lower control arms for $60-80.
Slawder95
Seth
Katy, TX
Try rotating the tires and see if anything changes before making drastic changes.
The amount of tire rotations, balances, and alignments I’ve done chasing this are crazy…have taken it to the dealership and two other mechanics. Both are stating they cannot figure out what is wrong.
Aonarch
Mike Hawk
North GA / MT
Hopefully they inspected all ball joints for play, steering box, drag link, etc.
Stock steering stabilizer?
I would want to add caster.
Gangplank
Vero Beach, FL
2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
What steering stabilizer are you using?
Possibly that -0.26 degree thrust angle in the rear. It should be closer to 0 degrees.
If this vehicle doesn't have adjustable control arms, it's possible that the control arm bushings have deteriorated in a way that the axles are no longer properly aligned/square in your frame. If you have adjustable control arms, after checking bushing condition, adjusting the axles to square to the frame is a starting point.
Gangplank
Vero Beach, FL
Need more info - stock suspension? Steering stabilizer?
The alignment should be in spec. It’s not.
Badunit
VA
1997 TJ, 2023 JT
Rear thrust angle on mine is 0.32 deg and it tracks straight, so probably not your rear thrust angle.
Does either wheel on that side feel like it is dragging, in comparison to the other side?
Is suspension level left-to-right in front and rear? Springs all seated properly?
Do you get any strange tire wear that might provide a clue?
embedded rock
In the path of a future Kentucky tornado
'24 JLUWX (traded) | JLRX for EJS'27? Let's see | CRF1000L, KLX300SM
So, your Jeep is STILL pulling to the right after the alignment? If so, some recommendations for suspect components have been mentioned.
How many miles on your '19 Jeep? Still original suspension and steering components?
BullMoose1776
Bull
South Texas
Project Manager
AEV Steering Stabilizer. AEV suspension. Upgraded track bar. Cant recall the brand. 37s. Bfg ATs. Stock aluminum steering box.
Had multiple alignments done. Finally gave up and just live with it.
JEEP4U
Richard
2021 Jeep Wrangler
Get your Camber and Thrust angle fixed.... Camber is way out of wack........with those actual's it would pull to the left.
you have something else going on
