Newbomb
I pieced together a lift and installed it on my wife's 21 JLU Sahara. It has less than 12,000 miles on it. Here are a list of the parts...
JKS 2.5" SD springs
Fox shocks
JKS front track bar
RK Rear track bar bracket
Teraflex rear sway links
Factory rear links moved to front
RK front and rear correction wedges
Mopar beadlock capable wheels
35" Kenda Kleever R/T's
RK X-factor front lower control arms
Stock steering stabilizer
Immediately has a gnarly right pull...even after 2 shops aligned it (who don't print out the specs). The RK LCA's rubbed so I put those to the side for when my JLUR gets here and installed a set of teraflex sport fixed front LCA's. The pull is still there, maybe 10-20% better but let go of the wheel, say "one Mississippi" and you're into the shoulder.
-I've verified front axle is centered
-I've driven it with and without the steering stabilizer, no change noted
-Rear axle seems to be centered best it can with the RK bracket
-I've adjusted tire pressure about 20 times to find a combo that would work
-I've done the steering reset
-I've rotated the tires 3 times.
Nothing has worked.
I don't want to drop more money on adjustable front LCA's after buying 2 sets already. I'm wondering if I bought adjustable front UPPER control arms, if I could slighty tweak it to drive straight (shorten DS and lengthen PS). What'ya think?
Also I'm probably crazy but it seems like at all times the steering wheel is "lighter" to turn right than it is left, at any speed.
JKS 2.5" SD springs
Fox shocks
JKS front track bar
Nothing has worked.
