Sagging in rear, spring replacement
daverockville
Rockville, MD
2024 Jeep Wrangler Rubicon X - 3.6L
I have a 24 Wrangler Rubicon 4 dr with extreme recon. The back of the Jeep is sagging 2 - 21/2 inches due to my overlanding setup. Any recommendations for Springs in the back to level out the Jeep? Also would I need to add anything else e.g. Bump stops…. I simply want to return it to stock height.
Trunty
Travis
San Antonio, Tx
2020 JLUR EcoDiesel
I have the same jeep and I’ll be installing Clayton 1.5” springs in the next couple of days. I don’t have as much weight in the rear, but I’ll let you know how it goes.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
I had the same issue, ended up installing rock krawler 4.5” springs and 1” spacers from terraflex to level my rig out.
Jeep Wrangler JL Sagging in rear, spring replacement IMG_3985
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
I have a 21 willys sport. I had the same issue but not until around 50K and after I had installed new shocks.
Point, I went with 1.5" Clayton ride right lift and it fixed it right up. Another up side to Clayton is the ride improved, plus when I add weight in the back of the jeep the ride gets even better.
daverockville
daverockville
Rockville, MD
Thanks, I am hoping to just get away with just replacing the springs with something that can carry the heavier load in the back.
Reinen
2021 Jeep Wrangler JL Rubicon
Old Man Emu Heavy Load Springs. They are made for carrying heavy overlanding loads and does it very well. Most lift manufacturers don't consider heavy cargo weight but that's what OME is all about.
You might be able to get away with just springs but I'd definitely double check. The OME 2" Heavy Load springs are 2" above Sport height, 1" above Rubicon height and maybe even with Rubicon Xtreme Recon? (As I said, double check).
daverockville
daverockville
Rockville, MD
Thanks, I was looking at Clayton and Old Man Emu. I ordered the Old Man Emu 3138 (heavy load) rear coil spring set just an hour ago :) I know the rubicon extreme recon sits basically a 1.5 inches over Rubicon based on what I have read on forum. According to ARB website for the whole lift kit which has a lot more: "the kit will net 3.5 in for non Rubicon models and 2.5 in for Rubicon models". I just ordered the rear springs from this kit (3138) so we'll see how it works out!
Previously I tried airbags (didn't help much) and right now I have a 3/4" daystar spacer which did raise it 1 inch in the back. But I am assuming the coil springs are a better solution since the airbags prevent the suspension to move up and down stops the springs from doing what they are suppose to do which may result in additional stress on other components, and the spacer still leaves the springs compressed more than they should hoping these heavy load springs compensate somewhat... I'll do some measurements before and after and will report back in case it's helpful to anyone else.
Reinen
Good call. Going with OME took me from big cargo problems (poor ride, sag, bottoming out) to cargo being a non-issue and greatly improved the ride.
The only downside to it is that I wouldn't recommend off-roading with it without your cargo weight. It will need the weight of your overlanding gear to really shine. However it's very nice on-road with or without the cargo weight.
daverockville
daverockville
Rockville, MD
Does anyone know the stock suspension heights in the front or back, I have 24 Rubicon X with 35s which would be same as JL Rubicon with extreme recon package?
So I installed the OME springs in the rear and here are my measurements. Assuming the Jeep should be level or some both in front and back, looks like I am a little off on Passenger front tire 3/4" lower so may need to install a 3/4 inch space in front? The 3 other side all look about 42 inches.
Jeep Wrangler JL Sagging in rear, spring replacement 1724248006939-m0
zouch
Berkeley, CA
XJ, JLUWD
why would you assume it's supposed to be "level"?
have you measured with a full load of passengers and/or freight? that's what really matters.
Nokones
Kenny
Sun City West, AZ
Don't forget about getting the shocks with the correct valving and travel length to complement the different spring rates and ride height change or you accomplish nothing insofar as having things right. The shocks have to be compliant with the springs.
daverockville
daverockville
Rockville, MD
Not sure, I am getti g different info. what should it be? I will probably add another 150- 200 lbs when fully loaded for a trip.
daverockville
daverockville
Rockville, MD
I want to return the back to same level as factory and wher e it was before putting the rack and all the stuff I have on it now. Assuming the ride height is back to where it was out of factory would I still need to do that?
Nokones
Kenny
Sun City West, AZ
If you change the spring rate the shock valving should match that different rate.
acheron800
FJ
2014 FJ Cruiser
Any updates on this?
Looking to get an inch or 2 in height back on a 24 X.
