SlickRickMotoADV
- Rick
- Mar 9, 2021
- El Sobrante, CA
- 2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
I have a 2019 Sahara with Rubicon suspension, wheels and tires, as well as the longer control arms from the Mopar lift kit. When I first installed the suspension, it was a nice upgrade and was noticeably taller than before. I started doing a bunch of modifications to the Jeep that added weight in various areas and it's started to look a bit low lately. I looked up how much fender clearance a Rubicon fender has on it's 33" tire, and it's about 7.5". With my lower fenders, I expected about 5.5", but would like as close to 7.5" as I can get.
I just recently installed Apex sway bar endlinks and am pretty certain that when unlocked, the front will contact. I am also concerned that the rear is going to contact something with as little clearance as you see below.
How it currently sits:
Driver rear sitting at about 4.5" clearance
Driver front sitting at about 5" clearance.
It's a little hard to tell, but I also think the passenger rear is about 4.25" clearance, maybe because I currently have a full tank of gas? The front passenger side is about on par with the 5" that I see on the front driver side.
I want to have as little lift via spacers or lift kit as possible. I would like to retain the OEM suspension feel if possible. Most of my use case is overlanding, so a bit of highway and some easier trails with a few OHV trails and harder areas thrown in.
Do I need 7.5" of clearance on top of the tire to full utilize 33" tires? I know this is a bit loaded of a question as my vehicle weighs more than most on stock suspension.
If I do need that much clearance, is the preferred route to go with something like a 2" spacer in the front and a 2.5-3" spacer in the rear? From the numbers I've seen in spacer discussions on this forum, that seems excessive. I'm also unsure of how this would impact the handling from the way it is now.
If spacers aren't the option, is something like the Dynatrac 2" Lift suitable?
Almost everyone I know who overlands in a jeep who has put a "real" lift kit on regrets how stiff it is for most use cases. I'm trying to avoid that, keep center of gravity low, and maintain the OEM feeling it has.
Let me know what you guys think.
