Pismo61
- Jul 18, 2021
- Temecula,Ca
- 2026 JLURX
Had Bilsteins on a JK,now on a JL.I like them and don't find them too firm.
Yes, stock: the fronts are 33-316314 (0-1.5” lift), rears 33-292632 (2-3” lift), it’s been flexed out at the max a few times. I didn’t adjust anything with the rear brake cables or lines either.Hi John. Is your suspension otherwise stock? Do you have the Bilstein part number for the shocks you purchased? Bilstein has a good online product selector allowing you to drill down to the engine and submodel (Rubicon X) but they still have different models based on lift height. I'm assuming that since my Rubicon X is stock it would be the models that are 0"-1.5"?
Interesting. Thank you. Is there a reason you went with the 0-1.5” in the front and the 2”-3” in the rear? Since you’ve had it flexed out can you confirm there was no driveshaft contact with the rzeppa flange on the front driveshaft with the Bilsteins? You didn’t by any chance get measurements on the stock front and rear shocks such as compressed length and fully extended length? Lots of questions but I sure appreciate it.Yes, stock: the fronts are 33-316314 (0-1.5” lift), rears 33-292632 (2-3” lift), it’s been flexed out at the max a few times. I didn’t adjust anything with the rear brake cables or lines either.
Well I think I read I could go a little longer on the rears. I did take measurements before I threw them away, guess I could have used the shorter ones on the rear.Interesting. Thank you. Is there a reason you went with the 0-1.5” in the front and the 2”-3” in the rear? Since you’ve had it flexed out can you confirm there was no driveshaft contact with the rzeppa flange on the front driveshaft with the Bilsteins? You didn’t by any chance get measurements on the stock front and rear shocks such as compressed length and fully extended length? Lots of questions but I sure appreciate it.
