Rear end nightmare
Geronimo
Boltz
2013 JKU , 2018 JLUR, 2023 JLR all DDs
Haven't actually torqued things to spec, but will certainly do so. Thanks! ???
Worn control arm bushings will clunk even if they are torqued to spec. Mine did. Just saying you must pull the bolt, drop the arm check to see if the bushing is "wallered" a bit. Should be no play in it.
RAMSTEEL
Rick
Virginia
2023 392 XR
Army (Ret), Fed Guy
Have someone get in the rear area and drive around, they might be able to get a better directional sense of the issue.
Another option is to grab some of those magnetic mini cameras and throw a couple under the rear and record what's going on.
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Thank you. It's actually a noticeable rattle going over rough city streets. Almost like a bottoming out sound but rattling, if that makes sense. ???
Roky
Roky
Help, I'm out of ideas. I have a crazy loud and worrisome rattle coming from rear passenger of my 2018 jlu. It's happening when driving on rough roads or over bumps. Sounds like something is bottoming out. Can't duplicate it bouncing. Had a look at the sway bar, links, control arms and all seem tight. Have a mopar lift with Fox shocks, purchased that way. Any ideas or insight is appreciated. Driving me mad!
I had the same type of noise, it ended up being in the door. I take them off it’s gone…. I haven’t looked into what exactly it is yet, but knowing where it’s coming from has eased my enthusiasm……lol…
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
Check your tailgate. I had a loud clunk coming from the rear and it turned out to be the tailgate. I tried this fix and it worked.
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Yes thanks. I actually tried that several times. No luck. ?‍♂
C2D2
2019 Jeep Wrangler Rubicon
I had a random plastic piece that was in the tailgate upon delivery. Pretty obvious when you shook the door back and forth. I’m guessing you tried that too?
Mocopo
Kevin
Arizona
holy crap, I had a JK that did this for a year, I never found the issue before I sold it. This has to be what it was lol (I didn't sell it because of the noise)
Beachcomber72
2022 JLU High Tide
You may try looking into it possibly being inside the rear top of the hard top. There are quite a few owners that have had some internal wiring harness that come loose inside the top itself and only clunks/rattles when over bumps. Most thought it was from under rear vehicle too. Just a thought.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
I have the same issue when i eat Taco Bell. Oh wait. Sorry. Wrong rear end.
Apples491
Nick
Denver, CO
2022 JLUR in Hydro Blue, 2024 Nissan Ariya
I'm surprised nobody has brought it up. Have you eliminated the possibility of a bad shock? it would certainly cause a bottoming out while driving but wouldn't be nearly as noticeable just jumping on the rear end.
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Sure have! Even took off the panel to have a look. It's like a clicking sound going over bumps. Definitely rear passenger.
