Rear end nightmare
VIJeepGuy
Robert
Canada
2018 JLU
Help, I'm out of ideas. I have a crazy loud and worrisome rattle coming from rear passenger of my 2018 jlu. It's happening when driving on rough roads or over bumps. Sounds like something is bottoming out. Can't duplicate it bouncing. Had a look at the sway bar, links, control arms and all seem tight. Have a mopar lift with Fox shocks, purchased that way. Any ideas or insight is appreciated. Driving me mad!
Some Random Guy
Washington
Comptroller
Don’t shoot me, but empty your storage cubby and the jack location. Totally possible something snuck in there and now sounds funny.
I know, dumb. For some reason sounds carry weird from back there. But a few threads like this have turned out that way. Free.99 and then we can get into the gritty.
kah.mun.rah
Merenkahre Jr.
Duat
Your evap canister is installed up inside of the rear passenger wheel well. Maybe part of it has come loose.
Geronimo
Boltz
2013 JKU , 2018 JLUR, 2023 JLR all DDs
Worn or bad control arm bushings did that on our JLUR with RK X Factor arms, (they were a bad batch of bushings that RK replaced for free) Anyway the sound you described is exactly the clunk sort of sound that it made. Also we could not duplicate it by bouncing the Jeep by hand or jerking and pulling on the arms. Took me months to finally figure it out.
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Did that, no luck, but thanks. ???
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Pulled the fender and tightened it down a little extra. Not the culprit unfortunately, but thanks. ???
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Crazy! Well she goes to the shop next Monday so I'll be sure to mention that as a possible source. Maybe a bad fox shock too. Thanks! ???
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
Rear jack could have come loose in the bracket.
ASMSAS
Marlene
NorCal
Aviation
Did you check that ALL the bolts on your hardtop are tightened down?
Rustydog
Palm Desert & Big Bear Lake, Ca
2019 JLU
All "seem" tight? As in you hit each with a torque wrench and torqued to spec? If not, I would 100% start there first. Upper lower controls arms front and rear, shock bolts, track bar front and rear.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Muffler bearings.
But in all seriousness your exhaust bounces everywhere. Have you wiggled it around? Some of the rubber isolation bushings could be bad.
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Haven't actually torqued things to spec, but will certainly do so. Thanks! ???
VIJeepGuy
VIJeepGuy
Robert
Canada
2018 JLU
Muffler bearings.
I have pulled at it a bit bit ill give it a more serious check. Thanks. ???
