Rear differential crap out
Alex12213
Alex
Ottawa
2019 Jeep JL Wrangler
My Jeep JL unlimited sport s currently has 16400 km on it and I had to bring it to the shop after is started making a noise in the rear every time I would take my foot off the gas. Dealer said they have to basically redo all the internals of my rear diff lol. Kind of said how jeeps are supposed to have rock solid diffs for off roading and my craps out with so few km and having done no off roading yet. Disappointed to say the least. Thank go for warranty. But guess I won’t be putting a lift or anything
TrewJL
Ryan
Tucson
JLU Rubicon
CEO
Any modifications to your jeep?
Alex12213
Alex12213
Alex
Ottawa
Theres no reason at all for this. Sorry best of luck with the repair.
Thanks. Scared to do any mods now just in case something happens again and warranty gets challenged:/
AlexJeepVB
Alex
Virginia Beach
2019 JL Rubicon 2.0T eTorque
Do you have the limited slip diff? I heard they can have problems early. Also I wouldn't worry to much since it should all be fixed under warranty.
Alex12213
Alex12213
Alex
Ottawa
I don’t believe so
Jamrock
Jamaica
Suzuki
You might want to check if you have LSD. There is a known issue with Sport, Sport S and Sahara Jeeps with LSD. The clutches wear out prematurely. Rubicons don't use LSD do they don't have this issue.
Replacing the part is not a permanent fix since your dealer will replace it with one that is likely to wear out prematurely.
It is not clear when FCA will have a true replacement part available.
https://www.jlwranglerforums.com/forum/threads/knock-in-rear-with-dana-44.16921/
Revolution_322
New Jersey
Jeep JL Rubi White
Its not all that uncommon over the great volume of manufacturing. Shimming a carrier is tricky business. Yr talking thousanths of inches for tolerance spec. Slightly off and the diff just wears itself out. Could just be a carrier bearing was faulty or pinion seal etc... its all good . Have them rebuild and youll be fine.
Germansheperd
Ted
Ohio
2020 JLU, 2019 HD FLHXS, 2018 Taurus, 2008 Mustang GT, 1994 Z28
Did you change your gear lube in the diffs?
Revolution_322
New Jersey
Jeep JL Rubi White
OP- if youre going to re- gear nows the time!
You probably get a discount too.
Alex12213
Alex12213
Alex
Ottawa
So it’s likely to happen again:/.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Alex12213
Alex12213
Alex
Ottawa
Why does this make you laugh out loud?
Because I thought Jeep diffs were tough. Built for off roading. Not breaking in 16400 km.
