Knock in rear with Dana 44
NO51
Nick
Pittsburgh PA
2018 JLU Sport
After my lift was installed between 10 and 20 mph when not hitting the gas I am getting a knocking sound sounds like possibly from the rear drive shaft and one have a fix for this?? I know on my Tacoma I added a driveshaft spacer after my lift to adjust the driveshaft angle anyone else experiencing this problem after a lift?
NO51
NO51
Nick
Pittsburgh PA
2018 JLU Sport
  • Thread starter
  • Thread Starter
  • #4
Probably need to supply more details to get help with this. What lift components/kit was used?
RC 2.5 coil lift with Fox shocks
Carlton
Chicago
Jeeps lots of jeeps
Is it a constant knock, or a random occasional knock?
If constant, 2.5 shouldn't be enough lift to cause issue with the rear drive shaft. If it was a taller lift, I'd suggest adjustable control arms.
There could be a driveshaft issue if the axle was dropped too much without disconnecting the shaft during install of the lift. Additionally, improper re-install if it was disconnected can cause issues.
If it is more of an intermittent knock, it could be a few things. 1. Over torqued or under torqued components. 2. A bushing sitting funny. 3. The coil spacers. Make certain they are installed from top to bottom: Spacer, factory isolator, coil spring. If they are out of order they will make a thump and crackling noise.
NO51
NO51
Nick
Pittsburgh PA
2018 JLU Sport
  • Thread starter
  • Thread Starter
  • #6
It’s not a spacer lift so I know that’s not the issue, it makes the noise between 10 and 20 mph all the time I will have to get under and check on the torque of the bolts or just see if I notice anything that seems out of place I’ll have to contact the shop to see if they disconnected the driveshaft during install
JMONEZ
Jared
el dorado hills CA
2019 JLUR
Self employed
I have the same sound, between about 7-16 mph 2 or 3rd gear with foot off gas and slowing down, can’t seem to figure it out( driveshaft, rear diff, suspension, wheel bearing) no clue! Knocking rotational noise and I can feel it also. I have a coil lift, 2.5 rubicon express
NO51
NO51
Nick
Pittsburgh PA
2018 JLU Sport
  • Thread starter
  • Thread Starter
  • #11
Glad I’m not the only one my buddy just bought a lifted Sahara with the Jeep lift already installed and his is also making the same noise
D Arnett
Darren
Indiana
2019 JLR 2.0t wrangler
I also have a constant knock between 3rd and 2nd only off the gas or steadily slowing down dealer appointment in a week. Checked every bolt under checked everything lol
NO51
NO51
Nick
Pittsburgh PA
2018 JLU Sport
  • Thread starter
  • Thread Starter
  • #13
Keep me updated it’s annoying at this point
Boothorp
New Jersey
2018 Wrangler JLU Sahara
I get the same thing! It's driving me mad! for me its pretty noticeable between 8-35 mph with foot off the gas. I really want it gone!
I have a 2.5 JKS with RK front adjustable control arms.
Boothorp
New Jersey
Does anyone that experience this have aftermarket rear control arms or is everyone stock? I have stock for now.
Smart Stop Start
