grimmjeeper
- Roy
- May 6, 2021
- Castle Rock, CO
- Website
- www.grimmjeeper.com
- 2021 Wrangler, 1987 Comanche, 1997 F250
- Build Thread
- Link
- Occupation
- enginerd
The 3.6 can handle a little more gear better. Shorter (higher number) gears let the 3.6 rev higher and that's where it performs better to a point.
For 35s, I wouldn't hesitate to run 4.88 gears, especially with the double overdrive in the automatic.
On the other hand, the automatic has such a wide gear spread that it's good at covering up "less than optimal" axle gear/tire size combos.
Given the intended use for the Jeep, I would spend money on 4.56 or 4.88 gears. Maybe lean towards 4.56. But I would also entertain swapping in Rubicon axles with 4.10s.
