please recommend hitch receiver...
ahmadtaha1988
ahmad
dubai
2023 JL 4 door Sahara
Hi All. My first jeep. 2023 Sahara 4 door. Can someone please recommend a hitch receiver that would install on this vehicle?
I would like a "strong" one as ultimately I may use some type of adapter to put a D ring on it.
I found many online. But in the reviews you always fine people saying it did not fit their vehicle correctly (bumper, screw holes etc)
Ultimely I would like to install this
https://www.google.com/url?sa=t&sou...EQFnoECBcQAQ&usg=AOvVaw3WeDXNX2UgPNyUhcA4OQ7g
Ten North Prez
Sweet Valley, PA
2023 JLUR, Toyota 4th Gen V8 4 Runner
Congrats on the new Jeep! Are you planning to add aftermarket bumpers?
Old Jeeper
Don
US Army Infantry, IT Engineer
Suggest you head down to one the BIG U Haul shops. They install these things all the time and they know what they are doing and will sell you what you need!
jludave
The Isle of Long
IT Manager
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
I installed this one on my '18. Took all of 15 - 20 minutes to install.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Every hitch I've seen has the same 3,500 pound rating, except the Max Frame from Draw-Tite:
Jeep Wrangler JL please recommend hitch receiver... 1677598833315
STW
2022 JLR 2door 2.0T Rubicon stingrey
of the ones I looked at, I liked the Curt best. It has great powercoating--no chips and seems durable inside the receiver too. One of the four bolt holes was slightly off on my Jeep, and required a bit of touch up with a die grinder. I think this is due to small differences in how they drill the holes in the Jeep frame, and slight year to year changes, not due to problems with how Curt or Draw-Tite or any of the other known quality hitches.
I managed to install mine without removing the (steel) rear bumper, even though Curt recommended removal. It was fiddly to locate a couple of the bolts to their nuts with bumper in place, but not too bad.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I installed and recommend the Curt 13392.
To accommodate fitment of two of the provided receiver hitch bolts, I did have to use a rotary tool with a coarse sanding drum to enlarge two of the corresponding frame crossmember holes. It required maybe five minutes to get both of them squared away.
The installation instructions did also suggest lowering the muffler to create necessary working space. With a bit of precision wiggling, though, the Curt hitch was positioned and secured in place without having to touch the muffler.
Note that you'll not want to exceed the vehicle's rated tongue weight and towing ability (as stated in the Owner's Manual), no matter if a particular hitch advertises a higher figure for either metric.
Jeep Wrangler JL please recommend hitch receiver... 1677599971850
Ten North Prez
Sweet Valley, PA
Pick one and install it yourself. Should take no more than 1/2 an hour. Be sure to use red Locktite.
https://www.quadratec.com/vehicle/jeep-wrangler-jl-parts/hitches-racks/hitches
Absolutely! It's four bolts that will come with the hitch and the holes are already in the frame. As previously posted, you can do this without removing the bumper. Those complaining of bumper clearance you referred to may have been talking about aftermarket bumpers as some wont clear a factory hitch. But the stock bumper will work with all of the hitches posted up thread as an example.
ahmadtaha1988
ahmad
dubai
thanks, I guess next season. I paid cash for it given interest rates, so cant justify major expenses.. Is it better for the car to recover it via points on the frame or via metal bumper?
Fudster
Elliot
Athens, GA
2019 Sahara
Hi Ahmad:
In your initial post of this thread you linked a hook designed to attach to an existing 2" receiver hitch and respondents linked you receiver hitches themselves, void of the component you linked.
Please appreciate, if you don't, that that which you linked first requires the installation of that (the receiver hitch) which respondents to your thread linked.
ahmadtaha1988
ahmad
dubai
Hi Ahmad:
Thanks everyone, still figuring this out. But love the support of the community. Cant wait to receive the car in a few days and start figuring out these basics.
Much appreciate the help!
Babeinsap
Abe
North carolina
2021 JLU Sahara Altitude; 2001 TJ
I installed this exact one on my 2021 Sahara I didn’t have to lower muffler, remove bumper or anything. No die grinding either. Did use a jack to lift it in place as it’s a tight fit on the existing frame. It’s a little longer receiver part than the model for the JK bumper which makes it fit perfect. Nice finish and quality. Got mine “used like new” on Amazon for like $60 bucks.
