Oversized Spare Carrier
tonyb1224
Tony
Bessemer, Alabama
2021 Wrangler Sport
I just lifted my 2021 Wrangler JL to put 35 tires on it. Bought a used 35 for the spare. I now know that there has to be some modification for me to be able to have 35 as a spare. They look really expensive. What are my options...if any?
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I believe the factory spare tire carrier can handle a 35" tire but you have plenty of options.
Jeep Wrangler JL Oversized Spare Carrier JEEP_JL_REAR_BUMPER_AND_TIRE_CARRIER4-750x563-3-1000900582
Jeep Wrangler JL Oversized Spare Carrier rugged-ridge-spartacus-hd-tire-carrier-kit-jl-11546.55-no-wheel_0-486133013
tonyb1224
Tony
Bessemer, Alabama
2021 Wrangler Sport
I have a 35 and have the factory spare tire Carrier. The only thing I had to remove was the rear camera cover.
I put the 35 up on the carrier but there wasn’t enough bolt left to put the lug nuts on. Did removing the comer cover allow more bolt to protrude?
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
Flip
Johnny
Virginia
Yea had to use that for my wife’s JK.. but that’s only because it was hitting the bumper
Did it work out ok, is it a good product?
If I ever increase my tire size, I'll have to do something.
Jeep Wrangler JL Oversized Spare Carrier IMG_20230518_140809202_HDR-1
lb.wallace
LB
Venice, Florida
2021 JL Rubicon
My 2021 has a 35 spare on factory carrier, but the builder added a slight body lift so there is plenty of room off the bumper (aftermarket too) and all I had to do was change to some cheap extended tire bump stops from Amazon because the factory ones were not touching the spare (as seen in pic first pic).
Jeep Wrangler JL Oversized Spare Carrier Screenshot 2025-02-08 at 1.15.45 PM
Jeep Wrangler JL Oversized Spare Carrier Screenshot 2025-02-08 at 1.14.09 PM
2nd 392
Ca
Avoid the steel relocation plates, they weigh ~15 lbs. I have an unused RC one in the garage after realizing it would put me at reinforcement weight. The TF aluminum ones are featherweight 2” up- 1 3/8” out IIRC. Unless you go to less offset wheels then spring for an adjustable like the TF Alpha to eliminate possible camera/sensor issues. The Alpha is much cheaper without the $75 first, then $150 second relocation cost added to the total. TF reinforcement can be added later if needed.
Jeep Wrangler JL Oversized Spare Carrier 1C45707D-62B7-40A9-A30C-D53D0DF8DA18
I don’t get the OP’s problem. It clears the bumper (?) , up against the bump stops ? Would the camera cover not be removed to mount it ?
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
The sport/willys have a different carrier then the rubicon. I couldn’t fit a 33” spare on my willys without removing the 3rd brake light. Once I removed the 3rd brake light the spare fit on the carrier but does rub a little on the bumper. I got the mopar relocation bracket to remount the 3rd brake light. It was cheaper for me to do the that compared to getting a new carrier.
Flip
Johnny
Virginia
I was looking for the weight on the RedRock but didn't see one. I would appreciate a link for the TF aluminum one if you have it.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
I installed Falken Wildpeak A/T3W LT315/70R17 tires, including the spare. No modifications needed.
