Oracle flush mount tail lights!!!
Ormond Beach, Florida
Retired at 55 ..
Yeah, saw the 2 options. Was hoping they incorporate more of their designs like the wave and stuff.
@Vanburi
Threedom's co-founder Carl Douglass, told me when I spoke to him at Jeep Beach 2022 that Threedom (Forum Sponsor) will be offering additional designs to include the Wave. The present two designs were just the first made available.
Why is, that there always has to be some dipchitt that has some why ass comment in a thread ....it's a shame they could not muster up helpful posts/comments versus posting pure crapola.
Threedom
Willmar, MN
mythreedom.com
Wrangler JLU & Gladiator
We got a ton of great feedback from Jeep Beach and are revisiting our priorities and design projects this week. We have our team plugging away at the designs. We'll provide an update in the coming week on when to expect the new designs.
Jreycnc
Jon
22 3.6/AT JLUR, 21 392
It was discovered that one of the machines on the line was leaving a light film of grease on a small section of the sealant channel, causing the sealant to not bond and thus, creating a small gap in the seal. This was caught quickly and the issue resolved.
If you were an early adopter and have not experienced this yet, you won't. This issue would immediately present itself on first contact with water.
There is not much of a DIY preventative that can be done here, since the red lens is so tightly fit into the housing.
Hey JP,
Have you guys had any issues with harnesses causing BSM errors? I plugged mine in today finally and get a Blindspot Monitoring Requires Maintenance message. I did some troubleshooting to identify that its the driver side taillight. Right one is good and the driver side works with the stock light & harness.
JP_Oracle
Peak Sponsor (Level 2)
JP
ORACLE Lighting
Hey JP,
PM'ed
JoeDoc359
Glenside, PA
2021 Jeep Wrangler Sport S
Firefighter
well we made it a month and a half and we've got the bottom 1/3 of a taillight out, looks like due to moisture. Anyone else experienced this?
Yes, I installed mine in February and noticed this just this past week. I sent an email to the Oracle email address that was provided a few pages back in this post.
Jeep Wrangler JL Oracle flush mount tail lights!!! inbound2070828532943661431
Trojan_Actual
Johnny
Wichita, Kansas
2020 JLU Sahara 2.0T
Retired Military
Hi! I have a tazer too. What did you mess with to get rid of the bulb out notification?
I have the LED package too and no hyperflash for me either. It was showing a tail out code on the dash but got rid of that with my Tazer. I love the look and those bulky tail lights are just a memory!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
From the Tazer instructions (worked for me)
• Set LED Tails: Configure the vehicle for LED taillights. If using aftermarket LED tails on a factory LED Jeep, switch this setting to NO then back to YES, this will clear the bulb out and hyperflash.
• Set LED Front Turn: This setting is to configure the vehicle for LED front turn signals. If using aftermarket LED turns on a factory LED Jeep, switch this setting to NO then back to YES, this will clear the bulb out and hyperflash.
• After configuration, perform a few 5 minute sleep cycles. Turn signals should be run for 20 seconds each before hyperflash and errors clear up
Trojan_Actual
Johnny
Wichita, Kansas
Retired Military
You rock. Thank you so much!
Trojan_Actual
Johnny
Wichita, Kansas
Retired Military
This a serious fix? Just asking because I for the life of me can’t get my tazer to work and I’m about to do your recommendation. Lol. Maybe I’m just an idiot.
You could always reinstall with the resistor and use a tazer to flash taillights to halogen and then it'll work just fine.
Jreycnc
Jon
Yes that will work. You just have to follow the tazer instructions for doing a reset after you make the change
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
So am I the only one seeing that the BSM "zone" has been moved from stock to 6' behind the vehicle? Only intermittent signals appearing from any vehicle along side.
