Oracle flush mount tail lights!!!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
mikem20
Woodland, Ca
2026 Rubicon XR
It’s a pain in the ass with the tazer but it does work to get rid of the rapid flash. I followed the instructions on a YouTube video.
Byrds8
Thought I read somewhere they were supposed to fix the hyper flash? Guess there goes me buying. I had no plans on a Tazer. LOL
Heimkehr
Pennsylvania
2021 JLU 2.0T
The only confirmed, post-release tweak that I've read about concerned replacing those tail lights, which were part of an early production run, that weren't sealed correctly during manufacture.
As far as hyper-flash and reduced functionality of the BSM function, the Tazer (and JScan too?) seems to be the accepted solution for the former. As to the latter, the consensus amongst most owners is that spotty BSM alerts can't really be improved upon, due to the fixed position of the sensor in the Oracle lights being different than in the OEM tail light.
Byrds8
Thanks for the reply. I guess Ill just keep the stock ones. They may not be the prettiest but I guess they do what they need to...mostly lol. My wife has halogen tails. Soon I am going to get her some 720lumen DiodeDynamic LEDs. Kinda envy her because I know how bright those suckers are.
Bocephus1963
Ceres, Ca.
2018 JLU Rubicon. 1976 K5 Blazer. 1995 S10 Blazer 4wd
Forklift Operator
I was among the first ones to buy these and i had the hyper flash as well and an occasional taillight out warning. Last year they came out with an inline pigtail that goes between the taillight and factory wires that solved all of the above. Maybe hit them up for the pigtail.
jhackathorne
Denver
'21 JLUR
I am pretty sure sometime within the last couple months they fixed the bulb out/flash issue. I have had zero issues with mine since I installed them a month ago. Only problem is BSM are spotty.
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Mine do not hyper but I get light out. ECRI fixed it.
david63
Overland Park, KS
2020 JLU Sahara, 2018 & 2015 2 door JK Sport
Wondering if anyone found a BSM solution. Mine does work but not the same as stock. The angle of the sensor is definitely more towards the back and less on the side. Only activates when’s car is much closer towards the rear.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Prior posts on the subject suggest that using shims to adjust the angle of the blind spot sensor provides a mild improvement when compared to not doing so.
The owner consensus seems to be that factory functioning can't be fully restored with the flush mount lights in situ; they simply don't allow the sensor to sit in the same position as do the factory tail lights.
tma777
Todd
Virginia
2022 JLUR XR
I have had these on my Jeep since July 2022, this past month I’ve been getting a random left turn signal out and hyper flash. I have the hyper flash modules installed and have enabled led with Jscan. I took the light off, checked the connections and everything looks good, it doesn’t do it all the time. I’m thinking I need to use Jscan and turn off/on led tails. Any thoughts?
ORACLE Terry
Peak Sponsor (Level 2)
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
I'm hoping this could be an easy solution. Please take a moment to fill out our online warranty request here: https://www.oraclelights.com/RMA and someone from our customer service department will be in contact with you shortly. Thank you!
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
waiting to buy a new pair. both of mine crapped out after 2 years. 1 turn signal intermittently stopped working and then both brake lights failed.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
Double check, make sure the front doesn't have a problem.
