Heimkehr
- James
- Sep 3, 2020
- Pennsylvania
- 2021 JLU 2.0T
If you want to spendWhen can we expect more panel design choices?
@VanburiYeah, saw the 2 options. Was hoping they incorporate more of their designs like the wave and stuff.
We got a ton of great feedback from Jeep Beach and are revisiting our priorities and design projects this week. We have our team plugging away at the designs. We'll provide an update in the coming week on when to expect the new designs.Yeah, saw the 2 options. Was hoping they incorporate more of their designs like the wave and stuff.
Hey JP,It was discovered that one of the machines on the line was leaving a light film of grease on a small section of the sealant channel, causing the sealant to not bond and thus, creating a small gap in the seal. This was caught quickly and the issue resolved.
If you were an early adopter and have not experienced this yet, you won't. This issue would immediately present itself on first contact with water.
There is not much of a DIY preventative that can be done here, since the red lens is so tightly fit into the housing.
PM'edHey JP,
Have you guys had any issues with harnesses causing BSM errors? I plugged mine in today finally and get a Blindspot Monitoring Requires Maintenance message. I did some troubleshooting to identify that its the driver side taillight. Right one is good and the driver side works with the stock light & harness.
JP has resolved my issue! Love these lights ?PM'ed
Can you PM me on whtever fix you have for the BSM needing maintenance error?PM'ed
Yes, I installed mine in February and noticed this just this past week. I sent an email to the Oracle email address that was provided a few pages back in this post.well we made it a month and a half and we've got the bottom 1/3 of a taillight out, looks like due to moisture. Anyone else experienced this?![]()
I have the LED package too and no hyperflash for me either. It was showing a tail out code on the dash but got rid of that with my Tazer. I love the look and those bulky tail lights are just a memory!
From the Tazer instructions (worked for me)Hi! I have a tazer too. What did you mess with to get rid of the bulb out notification?
• Set LED Tails: Configure the vehicle for LED taillights. If using aftermarket LED tails on a factory LED Jeep, switch this setting to NO then back to YES, this will clear the bulb out and hyperflash.
• Set LED Front Turn: This setting is to configure the vehicle for LED front turn signals. If using aftermarket LED turns on a factory LED Jeep, switch this setting to NO then back to YES, this will clear the bulb out and hyperflash.
• After configuration, perform a few 5 minute sleep cycles. Turn signals should be run for 20 seconds each before hyperflash and errors clear up
You could always reinstall with the resistor and use a tazer to flash taillights to halogen and then it'll work just fine.
Yes that will work. You just have to follow the tazer instructions for doing a reset after you make the changeThis a serious fix? Just asking because I for the life of me can’t get my tazer to work and I’m about to do your recommendation. Lol. Maybe I’m just an idiot.
