Oil Change Question
FJL40
Desert
2021 Rubicon 2dr 6spd
Do the JL’s have a oil drain plug crush washer?
Petey
Pete
Miami
2020 jl sport manual
I know this seems like an obvious question, but I don’t see one on the drain bolt. Factory forgot it? No oil leaking.
on some vehicles the washer gets stuck to the bottom of the bolt making it look like just a bolt with a thick base. Maybe its this?
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
on my 3.6 no, and it's 1/2 in not 13 mm. factory drain plug has some sort of gasket material on it.
I'm currently running aftermarket magnetic drain plug with copper washer.
Ormond Beach, Florida
Retired at 55 ..
@FJL40
No, no crush washer. Here is a pic of the drain bolt. That round metal, thick washer affair at the base of the bolt is not a washer but part of the bolt itself. Now, this thick metal washer may have some type of press fit insert of sorts (hard to tell by looking at it) that is not removable..
Also.... the oil pan drain bolt is not magnetized.
Jeep Wrangler JL Oil Change Question 20210309_102119
FJL40
FJL40
Desert
@FJL40
Awesome! Thank you! I got worried for a minute, but good to know it’s intended to be this way. Would it hurt to put a non-metal crush washer in between for insurance, or does this bolts seal remain good for a long time?
Retired at 55 ..
@FJL40
If it ain't broke don't fix it .. Another words NO, do not add a crush washer. As designed ... per FCA, no crush washer.
Most of the modern vehicles have a rubber O-ring in the face of the flange on the bolt. I don't recall if that's the case with the Jeep. It's been a while since I changed the oil.
Jeep Wrangler JL Oil Change Question 1662859437225
Heimkehr
Pennsylvania
2021 JLU 2.0T
Crush washers are easy to source (auto parts store, eBay, etc). They serve an important function and are inexpensive when purchased even in small quantities. Better to use the right part for the job.
txj2go
DFW
The seal at the drain bolt is rarely a problem. I would recommend that you get your bolt tight enough that it won't vibrate itself back out, I've seen that happen although in that situation there was some suspicion of vandalism. My father owned a garage for over 60 years and I've seen a lot of drain plugs.
Gripster
Graham
2021 Rubicon 2D
I bought a drain plug from the dealership and it had a rubber like material bonded to it. Yes, they have a seal to prevent the oil from leaking.
^ This
Jeep Wrangler JL Oil Change Question 1662864597054
CarbonSteel
Yes, they do.
Yeah, my forgetfulness. The first thing I do with every vehicle is toss the factory plug and install a Gold Plug which does have a crush washer. I use copper ones.
I forgot I changed it...lol
