Oil Change intervals
JakeM
Jake
Austin, TX
Ford F150,VW Atlas Cross Sport,24’ Wrangler Sport
took delivery of a factory ordered 2024 2 dr MT in January 2024, and after almost a year of ownership, I only have 849 miles. would changing the oil once per year be sufficient with the plan on only driving 1000 miles per year. any thoughts ?
azwjowner
Phoenix
Once a year is fine on a quality synthetic oil as long as your drives are fully heating the engine. If the reason you have only 849 miles in a year is that you drive 1 mile trips, then you need to change more often. Failure to thoroughly heat the oil to remove moisture is a problem.
rk911
Rich
DuPage County IL
'23 Wrangler Sport 2D, '10 Liberty, '46 Willys
Retired and loving it!
I have a 23 2door JL 8-speed auto with similiar low mileage. I. change oil every 6-mos. It's cheap and can't hurt so why not?
1quick1
Moderator
Moderator
2018 JLUS
I was doing mine once a year only driving 2,000 miles or so but I bumped it up to around every 8 months. It’s $30 and 20 minutes so I figured why not.
JakeM
JakeM
Jake
Austin, TX
Thanks ,what oil have you been using
Radioman
Kent
Roseville, CA
2017 Toyota Highlander, 2020 Ford Ranger, 2025 Jeep Rubicon
Retired Public Safety Communications Manager
I am a widower with 3 vehicles on which I drive a total of about 4,000 miles per year total. At the end of September after the heat of the summer and before the cool of winter, I service all three which includes a oil change. I use Mobil 1 synthetic oil.
Valpo Jeep
Doug
Valparaiso IN
15 Mas Ghibli, 18 JLU, 05 Gulfstream RV
Mobil 1 synthetic is a good choice. I am trying Pennzoil Platinum for this next interval.
Assuming you have the V6 then you need API oil that meets Chrysler spec MS-6395
yokramer
Snark Incarnate
With Amsoil or Royal Purple its a lifetime fluid
Valpo Jeep
Doug
Valparaiso IN
Why switching ?
Both are about the same price but an article I read listed the Pennzoil as a better oil. I tried Liquimoly in the past as it made the engine in my Audi run much smoother and quieter over Mobil 1 but I did not see that in the Wrangler.
