OEM tire iron question.
azjl#3
North AZ
It's not. Pretty sure...
Axel torgue is 130 ft-lb.
Tailgate torgue is 59 ft-lb.
Hate to say I googled it but I think it was a mopar service bulletin.
Eyeball
1997 TJ & 2023 JLUR
Can I reasonable use the OEM tire iron and its short length and readily undo the 130# torque?
Seems I need to carry a longer breaker bar and socket but will tire of carrying extra crap.
Thanks
Nobody on this forum has any idea how strong you are. But there is a simple answer… Try it in your driveway and have a 100% accurate answer to your question.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
rcadden
Ricky
Asheville, NC
Marketing
You'll also need something like this, the lug wrench doesn't come with a 22mm socket. https://www.amazon.com/dp/B098JJFCYH?psc=1&ref=ppx_yo2ov_dt_b_product_details
I got this one to accommodate any future distortion of the lug nuts.
100%. The first time I tried to do my own rotation (after my three free ones) took me nearly 3hrs because of bloated lugs. The damn socket got stuck on every one of them.
Someone suggested a 22.5mm socket and I thought they were trolling me. Bought it and my next rotation was butter smooth. Highly recommend.
zouch
Berkeley, CA
XJ, JLUWD
maybe the dealer should RTFM too?
wheel lug nut torque is clearly listed as
130 Ft-Lbs (176 N·m).
(spare is 59 Ft-Lbs (80 N·m).)
of course, the factory lug nuts are cheesy things with their decorative cover; i carry the ones that were replaced by my locking lug nuts to use as spares when the covers on one of the nuts distorts enough to fall off.
I'm still confused how lugnut torque can be a range of 85 up to 125ft.lbs?....... That must be why the dealer stripped off two lugnuts a few years back, tried charging me for them too.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
azjl#3
North AZ
Thanks I always thought 85ft/lb was spot on.
Was it 85 in the JK maybe?
Flip
Johnny
Virginia
I know 130 lb is the recommended torque spec but I felt comfortable going just a little less, I think I went with 120 lb.
LEDS
Leif
Anchorage
2008 WRANGLER RUBICON UNLIMITED, 2023 Rubicon 392
I like the foam insulation idea, but I never carry my tire tools in the floor compartment in the back.
The first time you need to unload everything from the back of your Jeep onto a dark narrow road, or in the rain, or in an endless sea of mud, you won't carry them there either.
RJP
RJ
Wisconsin
'23 Jeep Wrangler 392
Consider keeping a 16" breaker bar with the appropriate size socket in your JL at all times.
I have the socket attached to the breaker bar and the tool is placed in a 18" long piece of gray, foam pipe insulation. (No rattle.. no metal to metal contact, thanks to the foam pipe insulation)
I keep this affair, in the small compartment where the scissor jack is.
Fits right in on top of the scissor jack. With the foam pipe insulation, I have no metal to metal related rattles.
I also keep an LED flash light in with the scissor jack
I learned long ago, you can be up chitt creek so to speak, sometimes trying to break lugs loose with the little tire iron that comes with the Jeep.
Once you see someone standing on a tire iron trying to break a lug loose and the lug snaps off, etc., you realize wise man/gal carries a breaker bar with socket as I do, in the vehicle at all times.
Wise advice. ????
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
Can I reasonably use the OEM tire iron and its short length and readily undo the 130# torque?
Thanks
Try using it if it don’t work. It won’t work
Flip
Johnny
Virginia
Blade1668
Darrell
N Alabama
91MJ,90XJ,91XJ,05,LJ,05JT
If anyone has a hydraulic bottle jack you can possibly use the handle as a cheater bar on tire iron. In my Wrangler, I'll just snag the High-Lift jack handle. ;) In my JT I have a 2ft breaker bar.
BTW: Not my first choice to use any stock scissor jack I think of most being a one time use if that. Now the military Hummer jack :like: especially if you find a N.O.S. up-armor one.
